Atmega32u4 adc dc level problem
8 posts / 0 new
Dear Experts,
For an ADC based project, I have to get ADC samples from multiple  ADC  channels of an atmega32u4 uC.
Channels ADC2,ADC3,ADC4 and ADC5  are multiplexed with TCK,TMI,TDO,TDI pins of uC.
I get valid samples from other channels but for this 4 channels I get samples with DC level on them.
Could you please tell me how I disable JTAG operation and make my ADC channels give me samples without DC level?
Best Regards
Mehrdad,
Look at Table 28-4 on page 348 of the ATmega32U4 Datasheet.
Bit 6 of the High Fuse Byte is JTAGEN (JTAG enable bit) which
comes from the factory as Programmed (set to 0) which enables JTAG.
Unprogram  JTAGEN (set to 1) to disable JTAG.
Thanks Chuck
But suppose I would like to do it by using avrdude command under linux.
Could you please tell me how?
I found something like this from other forums.
avrdude -U hfuse:w:0xD9:m
Do you approve it?
BR
Mehrdad,
I don't have a lot of experience with avrdude,
so hopefully someone else will jump in to help you.
How are you programming the ATmega32U4?
As I understand it, you need to use an external hardware programmer
to change the fuses.
It says (in the datasheet. Please forgive me) to disable jtag, write MCUCSR=0x80; twice.
I use avr-gcc under linux and aspusb to program the board.
When I add MCUCSR=0x80; instruction , it does not compile.
It seems I need to add some #include files.
With GCC you usually need to add io.h as the first include file. From Studio file
#include <ctype.h>
#include <stdint.h>
#include <stdio.h>
etc.
Thanks Experts,
By using avrdude command line option the problem totally removed and I could disable JTAG port of my atmega32u4 uC.
I mean this:
