Xmeg128A1 SPI issue! need help
3 posts / 0 new
hello every one
I'm working on implementing radio transceiver nrf24l01 on xmega128a1 via SPI,
at first i just want to write data on RF_setup register than read the same data i wrote, but the function return  0 and not the value i wrote.
i think i have a problem with my spi init because my code works well on arduino
here is my code and any help will be appreciated
thank you
#define SPIPort PORTD
#define SPIMO   7
#define SPIMI   6
#define SPISC   5
#define SPISS   4
void ceHi()
	PORTJ.OUTSET = (1<<3);
void ceLow()
	PORTJ.OUTCLR = (1<<3);
void csnLow()
	PORTD.OUTCLR = (1<<4);
void csnHi()
	PORTD.OUTSET = (1<<4);
void spiopen(void)
	SPIDir = SPIPort.DIR ;
	PORTJ.DIRSET = (1<<3); // ce pin as output
	SPIPort.DIRSET =  (1<<SPISS);
	ceLow();
	csnHi();
	SPIPort.DIRCLR = (1<<SPIMI);
	SPIPort.DIRSET = (1<<SPIMO) | (1<<SPISS) | (1<<SPISC) ;
	SPID.CTRL = SPI_ENABLE_bm | SPI_MASTER_bm | SPI_MODE_0_gc | SPI_PRESCALER_DIV64_gc;
uint8_t spi(uint8_t val)
	SPID.DATA = val ;
	while(!(SPID.STATUS & (1<<7)));
	return SPID.DATA;
// read register from nrf24l01
void readr(uint8_t reg,uint8_t *value,uint8_t leng)
{       csnLow();
	spi(R_REGISTER | (REGISTER_MASK & reg)); // defined in the datasheet R_register to read and W_register to write
	uint8_t i;
	for(i = 0;i < leng;i++)
		value[i] = spi(value[i]);
	csnHi();
uint8_t read_rf_setup() // function to read the rf_setup reg
	uint8_t a;
	readr(RF_SETUP,&a,1);
	return a;
void configReg(uint8_t reg, uint8_t value) // function to write on register
	csnLow();
	spi(W_REGISTER | (REGISTER_MASK & reg));
	spi(value);
	csnHi();
int main (void)
	// Insert system clock initialization code here (sysclk_init()).
	board_init();
	spiopen();
	configReg(RF_SETUP,0x06 // write 0x06 on rf_setup register
		f=read_rf_setup();
#define SPIMO   7
#define SPIMI   6
#define SPISC   5
#define SPISS   4
Looks like you have swapped MOSI and CLK there. Obviously that only makes a difference if this is also how you connected the nrf24l01.
/Lars
Thank you for your reply
MOSI 5 and SCK 7 that's true, but that it doesn't matter, the initialization still correct because the pin connection is correct.
My code is fine and The communication works now, the pin header weren't welded well.
