Wireless Mesh Stack and External Clock Source?
3 posts / 0 new
Hi All and Alex
I am using the ATMEGA 1284p and AT86RF233 with the Mesh Stack.
I would like to know how I can swap the clock source from the internal RC to the clock being outputted on CLKM pin from AT86RF233?
I have set the fuse on the AVR to an external input, but I am guessing there is much more then that?
Ideally I would like to set it to 8Mhz or 4Mhz.
Thank You
Regards
Regards
DJ
djoshi wrote:
 the Mesh Stack.
Which "Mesh Stack"?
This one: http://www.atmel.com/tools/light... ?
Just select external clock in the fuses, that's it if you want to run at 1 MHz (the default for the radio). If you want higher frequency, then you'll need to program the radio to provide that frequency. It is a simple register write, you can put it in the PHY_Init() function, for example.
