Problem with SPI using BitCloud 1.14 .
8 posts / 0 new
Hi everybody,
   I'm using a ATZB-900-B0 with Bitcloud 1.14.
I tried to write a small code that get from a ADS8344 (can 16 bits) data through SPI port.
It works good the data are correct.
The problem is that it is very slow...the system takes around 5 ms to perform a conversion
I have a general timer calling every 2 ms the function  readTempSPIData_0;
The acquisition is not complete beacause the system is always inside the function when the timer fired again !!!
What is wrong in my code?
//---- declaration of my SPi descriptor
  spiMode.tty       = SPI_CHANNEL_0,
  spiMode.clockMode = SPI_CLOCK_MODE0,
  spiMode.dataOrder = SPI_DATA_MSB_FIRST,
  spiMode.baudRate = SPI_CLOCK_RATE_2000,
  spiMode.callback  = NULL;
//----- function called trough a general timer
void readTempSPIData_0(void)
  int i;
  uint16_t res=0;
  uint8_t tmp2, tmp3, tmp4;
  GPIO_0_clr();
  for (i=0;i<3;i++)
      page_spi.buffer[i] = 0;
  HAL_WriteSpi(&spiMode,&cmd_can,1);
  HAL_ReadSpi(&spiMode,page_spi.buffer,3);
  GPIO_0_set();
  acquisitionBusy = false;
  tmp2 = page_spi.buffer[0];
  tmp3 = page_spi.buffer[1];
  tmp4 = page_spi.buffer[2];
  res = ((uint16_t)tmp2)<<9 | ((uint16_t)tmp3)<<1 | ((uint16_t)tmp4)>>7;
  jauge = res;
Forget about BitCloud SPI driver and write your own. SPI peripheral is extremely simple.
Thanks for this answer Alex. Can you suggest one or more than one example source code that I can use for this kind of application.
Regards
Total votes: 2
Example of a simple SPI driver can be found in LwMesh SDK, for example. But it is very easy and goes something like that:
void spi_init(void)
  // TODO: Setup CS, MOSI, SCK pins as outputs and MISO as input
  SPCR = ((1 << SPE) | (1 << MSTR));
  SPSR = (1 << SPI2X);
uint8_t spi_write(uint8_t value)
  SPDR = value;
  while (!(SPSR & (1 << SPIF)));
  return SPDR;
That's all you need.
Alex, thanks for your quick answer.
The code is now :
  uint8_t buffer[3];
  for (i=0;i<3;i++) {buffer[i] = 0;}
  spi_init();
  GPIO_0_clr();
  spi_write(cmd_can);
  for (i=0;i<3;i++) {
        buffer[i] = spi_write(0);
  GPIO_0_set();
Is it correct or not?
You only need to do spi_init() once and there is no need to initialize the array to 0, you will overwrite it later anyway. Otherwise it looks good.
Don't forget to initialize SPI pins.
Thanks alex. It works good.
Regards Malek
Hi Alex,
   this is my final code :
void spi_init(void)
  GPIO_USART0_RXD_make_in();
  GPIO_USART0_TXD_make_out();
  GPIO_USART0_EXTCLK_make_out();
  UBRR0 = 0;
  UCSR0C = (1 << UMSEL01) | (1 << UMSEL00);
  UCSR0C |= ((0 << UDORD0)| ((1 << UCPOL0) | (1 << UCPHA0)));
  UCSR0B = (1 << RXEN0) | (1 << TXEN0);
  UBRR0 = SPI_CLOCK_RATE_2000;
  // Send data
  UDR0 = value;
  while (!(UCSR0A & (1 << RXC0)));
  return UDR0;
Every thing is ok but it seems that the problem is still here : the time to perfom a conversion is always around 5 ms.
Very strange...I will investigate !!!
Regards Malek
