I have observed that the input and output logic levels(voltage levels)are same for the transceiver AT86RF212. Usually the input low-high range is less than the output low-high range. Is there a mistake in the datasheet?
AT86RF212 has a direct interface with AT1281V in Atmel's schematics but when I checked the logic levels, they do not match as AT1281V's V0H IS 2.3V and AT86RF212's VIH is 2.6V if we take Vcc as 3V. Please someone help me with these issues as I have an ongoing project with AT86RF212B and AT1281V.
Thank You
