I installed AS7, after the launch of the next message. What could be the problem?
AS7 problem
MOD: Please don't hijack threads.
The backend process (atbackend.exe) isn't running. Did you get any error messages during installation?
1. Was there any error during installation?
2. Can you find devices and packs in Device Pack Manger?
(Open Device Pack Manager from Atmel Studio (Atmel Studio Menu -> Tools -> Device Pack Manager )
Can you please attach the following logs. You can find the logs here..
1. PackMgrlog from Windows Temp folder (%temp%\AtPackMgr.log)
2. Application Status log (%appdata%\Atmel\AtmelStudio\7.0\ApplicationStatus.log)
No, The installation completed OK.
This is log files
I have exactly the same problem.
I installed AS7 (version 7.0.582) on Windows 10 with pre-installed Visual Studio 2015 (maybe it's important).
After the installation on the start screen i got message: "Content Load Error."
And i also couldn't start project with the same message as topic starter had.
I think, problem is name of your user folder - "Riszt Péter". Create a new user ( for example, "Riszt Peter" ) , log in to your new account and try to run AS7. I had a folder with my name Michał and I had the same problem. Renaming a folder () solved my problem . Be careful if you want to rename a folder - learn how to safely do so.
The problem is solved on the basis of the previous idea, thank you all for your help
This issue is fixed in latest update (Atmel Studio 7.0 (build 594)). You can find the new update details in Atmel studio Notification window.
