SAMC21 32-bit timer not counting more than 16 bits.
9 posts / 0 new
SAMC21 Xplained Pro. AS6.2, ASF3.27
16-bit timer works fine, hits the overflow callback.  When I change to 32-bit only 16-bits of the counter is used.
I used the setup from the "TC UNIT TEST".
in the debugger screenshot to follow, you can see that TC0 is enabled & set to 32-bit.
you PROBABLY still have the debug watch window displaying tc_test0_module.hw->COUNT16
the way that ASF seems to define peripherals with multiple "modes" has a different data structure for each mode "high up" in the structure, even if most of the registers are essentially parallel.  But when you finally get to COUNT.reg, it will be only 16 bits instead of 32.  (well, this explains the debug window only showing 16bits.  What's the indication in your code that it's only using 16 bits?)
When I print the value it is only a value that would fit iin 16-bits.
also note that on the right the i/o register for the 32 bit count only show values in the lower 16 bits.
Here is a picture of the output.  The top half is with a 16-bit counter and counting the overflows in a callback.
The bottom halt is the same program, only changed the timer counter size.
loop code:
		    port_pin_toggle_output_level(LED0_PIN);
			port_pin_toggle_output_level(PIN_d2);
			for (int xx = 0;xx < 48000000;xx++)
				cntr++;
			//cntr++;
			//snprintf(String, 10, "%d", cntr);
			//puts(String);
			looptime = ((tc_get_count_value(&tc_instance)));
			printf("Looptime is: %u\r\n",(unsigned int)looptime);
			printf("count  is: %d\r\n",cntr);
			printf("Overfl is: %d\r\n",overfl);
			overfl = 0;
			cntr = 0;
I am reasonably certain that the SAMc21 is not counting more than 16 bits.
Here is a screenshot of the debugger.  I have circled the items of note. In the upper left the debugger did enter the TC_COUNTER_SIZE_32BIT return.
In the lower left, the 32bit counter only has a 16bit value.
on the upper right, the mode is set to 32bit.
Another screenshot of the debugger.
Upper left.  Assembly to load from counter into R3.
On right see R3, only has a 16bit value.  Still can't get the 32bit value to show.
Happy to say I found the problem.  In ASF tc.c there is an error on indexing into an array for values to be used setting up the MCLK timer for the slave TC.
In tc.c there is an error setting up the user interface clock in the MCLK for the slave TC
/* Enable the user interface clock in the MCLK */
system_apb_clock_set_mask((enum system_clock_apb_bus) inst_mclk_apbmask[instance*2],
inst_mclk_apbmask[2*instance+1]);
/* Enable the slave counter if counter_size is 32-bit */
if ((config->counter_size == TC_COUNTER_SIZE_32BIT) && (instance+1 < TC_INST_NUM))
system_apb_clock_set_mask((enum system_clock_apb_bus) inst_mclk_apbmask[instance*2+1], (ERROR should be *2+2)
inst_mclk_apbmask[2*instance+2]); (ERROR should be +3)
The correct lines should be:
system_apb_clock_set_mask((enum system_clock_apb_bus) inst_mclk_apbmask[instance*2+2],
inst_mclk_apbmask[2*instance+3]);
Here is the array of MCLK APB mask bits for the different TC
/* Array of MCLK APB mask bit position for different TC instances */
uint32_t inst_mclk_apbmask[] = {SYSTEM_CLOCK_APB_APBC, MCLK_APBCMASK_TC0,
SYSTEM_CLOCK_APB_APBC, MCLK_APBCMASK_TC1,
SYSTEM_CLOCK_APB_APBC, MCLK_APBCMASK_TC2,
SYSTEM_CLOCK_APB_APBC, MCLK_APBCMASK_TC3,
SYSTEM_CLOCK_APB_APBC, MCLK_APBCMASK_TC4};
I must say that it is 2 for 2 on errors in the ASF Example code.  In the Tsens code and in the TC code.
I know this is an old post, but I just want to point out the above is still an issue 2 years later in the most recent version of asf (3.35.1) to date and this fixed it.
Thank you for the information, they are very helpfull.
You also mentioned that there is a bug in tsens code also! Can you please say where is the bug, because I want to use internal temperature, but he values are not correct.
I suspect that there is something wrong with configuration of tsens, but for now I did not found the solution.
