ESP8266 connection problem
2 posts / 0 new
hi, ı hooked up ESP8266 Module like image, ı supply 3.3 V from power supply, but it consumes 110-120 mA current so, chip which is on module heats
ı tried to connect different resistor(5k,10k..) to between CH_PD and 3.3V but result did not change when ı interrupt connection with CH_PD, everything is
ok but ı know that ı can't send AT commands by this way, already ı could not execute any communication between Teraterm and ESP8266.  what shoul ı do?
If it is really a USB to TTL adapter, then it will have 5V outputs, which ESP8266 will not like.
