Hi Team!
I have been rearranging my project files in order to be able to reference all the bitcloud components within the application itself. However, after some rearranging, I have found that for some reason when I compilied my application, the "WdtInitatmega256rfr2_Gcc.o" file went missing. Go to my bitcloud/lib and the file no longer exists. In the past I simply copied the file from the original library, but it has been starting to bother me that I can't simply 'compile it'.
My HAL make log:
C:\BitCloud_MEGARF_3_2_0_modified\BitCloud\Components\HAL>make all clean make all -C ./../HAL/avr make[1]: Entering directory `C:/BitCloud_MEGARF_3_2_0_modified/BitCloud/Componen ts/HAL/avr' ---------------------------------------------------- HAL library creation. ---------------------------------------------------- avr-gcc ../avr/atmega128rfa1/common/src/halWdtInit.c avr-gcc ../avr/atmega128rfa1/common/src/halPwm.c avr-gcc ../avr/atmega128rfa1/common/src/halSleepTimerClock.c avr-gcc ../avr/atmega128rfa1/common/src/halSecurityModule.c avr-gcc ../avr/atmega128rfa1/common/src/halDelay.c avr-gcc ../avr/atmega128rfa1/common/src/halAppClock.c avr-gcc ../avr/atmega128rfa1/common/src/halClkCtrl.c avr-gcc ../avr/atmega128rfa1/common/src/halUsart.c avr-gcc ../avr/atmega128rfa1/common/src/halIrq.c avr-gcc ../avr/atmega128rfa1/common/src/halTwi.c avr-gcc ../avr/atmega128rfa1/common/src/halEeprom.c avr-gcc ../avr/atmega128rfa1/common/src/wdt.c avr-gcc ../avr/atmega128rfa1/common/src/halSleep.c avr-gcc ../avr/atmega128rfa1/common/src/halAdc.c avr-gcc ../avr/atmega128rfa1/common/src/halSpi.c avr-gcc ../avr/atmega128rfa1/common/src/calibration.c avr-gcc ../avr/atmega128rfa1/common/src/halInit.c avr-gcc ../avr/atmega128rfa1/common/src/halFlash.c avr-gcc ../avr/atmega128rfa1/common/src/halRfCtrl.c avr-gcc ../avr/atmega128rfa1/common/src/halMacIsr.c avr-as ../avr/atmega128rfa1/common/src/halW1.s avr-as ../avr/atmega128rfa1/common/src/halCalibration.s avr-as ../avr/atmega128rfa1/common/src/halSpDriver.s avr-gcc ../avr/atmega128rfa1/../common/src/pwm.c avr-gcc ../avr/atmega128rfa1/../common/src/sleepTimer.c avr-gcc ../avr/atmega128rfa1/../common/src/appTimer.c avr-gcc ../avr/atmega128rfa1/../common/src/halTaskManager.c avr-gcc ../avr/atmega128rfa1/../common/src/usart.c avr-gcc ../avr/atmega128rfa1/../common/src/w1.c avr-gcc ../avr/atmega128rfa1/../common/src/irq.c avr-gcc ../avr/atmega128rfa1/../common/src/resetReason.c avr-gcc ../avr/atmega128rfa1/../common/src/i2cPacket.c avr-gcc ../avr/atmega128rfa1/../common/src/eeprom.c avr-gcc ../avr/atmega128rfa1/../common/src/timer.c avr-gcc ../avr/atmega128rfa1/../common/src/adc.c avr-gcc ../avr/atmega128rfa1/../common/src/spi.c avr-gcc ../avr/atmega128rfa1/../common/src/sleep.c avr-gcc ../avr/atmega128rfa1/../common/src/flash.c avr-ar ../../../lib/libHAL_MegaRf_Atmega256rfr2_8Mhz_Gcc.a -td ../../../lib/WdtInitatmega256rfr2_Gcc.o -td ../../../lib/libHAL_MegaRf_Atmega256rfr2_8Mhz_Gcc.a make[1]: Leaving directory `C:/BitCloud_MEGARF_3_2_0_modified/BitCloud/Component s/HAL/avr' make clean -C ./../HAL/avr make[1]: Entering directory `C:/BitCloud_MEGARF_3_2_0_modified/BitCloud/Componen ts/HAL/avr' ---------------------------------------------------- HAL component cleaning. HAL cleaning done! ---------------------------------------------------- make[1]: Leaving directory `C:/BitCloud_MEGARF_3_2_0_modified/BitCloud/Component s/HAL/avr' C:\BitCloud_MEGARF_3_2_0_modified\BitCloud\Components\HAL>pause Press any key to continue . . .
I am unsure what the -td line does that is supposed to create the WdtInitatmega256rfr2_Gcc.o file. Is it that I am doing something wrong for this file not to be created or...?
