Non-Standard Zigbee data rates
3 posts / 0 new
I have seen that many 802.15.4 radios have non-standard data rates.  I would guess that the 250k rate will work between all radios that claim to be 802.15.4 because they are following the standard.  Now, if I were to use a non-standard data rate, I would expect all chips from a specific manufacturer to (hopefully) work with each other at any of the available data rates (i.e. a bunch of atmel radios at 2Mbps).  Now, I am trying to understand if radios from different manufacturers using non-standard bit rates would work together.  My guess is no, because the chipping sequence between radios is not standardized (802.15.4 only defines 250k as I understand it), and is likely proprietary (I've received communications from Atmel indicating this is the case).  Any info on this is appreciated.
I've gotten independent confirmation from Atmel that their 802.15.4 radios will indeed not work with other manufacturer's at higher data rates.
Some actually might. In Atmel case, high data rate is achieved in a most obvious way - by removing spectrum spreading and using the entire channel bandwidth for the data. You can expect others to do a similar thing, but that has to be verified on a case by case basis.
