PB megaAVR announced
54 posts / 0 new
Home > About Atmel > Press Room
Releases
Atmel Launches Next-Generation Low-power 8-bit AVR MCUs
Accelerating Development of Low-Power Applications, New megaAVRs Deliver Low Power, Additional Analog Functionality and Pin-to-Pin Compatibility For Designers of All Levels for Smart, Connected Designs
San Jose, CA, November 11, 2014
http://www.atmel.com/about/news/release.aspx?reference=tcm:26-64316
New Features
- Unique ID for every device enabling a more secure device for IoT applications and wireless networks
- Improved accuracy of internal oscillators for UART serial communications
- Improved accuracy of internal voltage reference for better analog-to-digital conversion results
Development Kits and Ecosystem
(Xplained Mini)
Availability
The Atmel mega168PB, mega88PB and mega48PB are available in 32-pin QFN and QFP packages with additional devices available later this year. All devices are sampling now. Production quantities for the mega168PB devices are available now while the mega88PB and ATmega48PB devices are available in February 2015.
Home > Products > Microcontrollers > AVR 8- and 32-bit MCUs
ATmega168PB Xplained Mini
http://www.atmel.com/tools/mega168pb-xmini.aspx
Home > Products > Microcontrollers > AVR 8- and 32-bit MCUs > megaAVR MCUs
ATmega168PB
http://www.atmel.com/devices/atmega168pb.aspx
Digi-Key has stock.
http://www.findchips.com/search/atmega168pb
Interesting.  Especially the pricing--quite a drop from A.  (AVR8 prices jumped maybe 30% in the past few months.  Perhaps with the lower-cost B line coming out, it makes sense...)
Putting aside the pricing, what do we learn from the product announcement?  Low power; unique ID; improved USART.
What are the errata?
12.3.1 Rev. A
– Wrong device ID when using debugWire
– Power consumption in power save modes
– USART start-up functionality not working
Parts in stock, and no full datasheet posted?!?
Newark is showing no stock, and pricing of 127c for qty 1000+.
The 168PA-MMH is on special for 154c at qty 1.
What I can't figure out is whether it has an internal 32khz RTC, or is it just the old async timer support with a 32khz external crystal?
"Power-save Mode: <1.0μA (Including 32kHz RTC)"
Well, it is still really early for the supply chain to settle out on "real" pricing.  But didja notice that DigiKey is "1,000 0.97179" and the listed reel-of-2000 price is .66 ?
I doubt there is an internal RTC (as found in for example Xmega).  From the existing PA datasheets:
Which is curious, BTW.  The new PB summary:
How is that better?
12.3.3 Rev. C
       No known errata.
joeymorin wrote:
How is that better?
Sometimes one will hear from the manager "It's good enough".
CR cell leakage is very low; a bit more may not matter other than for the smaller CR.
As the process geometry reduces the leakage increases; keep those old fabs primed and alive.
I'm guessing a process shrink with some improvements (ref, clock) and such.
"Throw us a bone!"
I can't speak to the better ref, but as for a better clock with process shrink I'm skeptical.  The last process change to the 'A' resulted in worse clock performance.  Older AVR models have a much more stable internal clock (less jitter).  I recall reading material from Atmel which explained the change to the 'A' came with greatly reduced silicon real estate for the oscillator.  This reduced power consumption, but increased clock jitter.  Of course I can't find and threads which support this (search rage!).
Something other than process shrink must be behind the improved clock.  However I note that the 'improved clock' makes no mention of jitter, only of finer calibration capability.
It is hard to do much "exploration" without the full datasheet.
The mention of "8-channel 10-bit ADC with Temperature Measurement" along with only two listed packages implies "DIP is dead"?
pb isn't that short for lead? Will this product sink?
Cannot be installed into products in ROHS countries.
Didn't notice that.  The TQFP is usually more expensive than the QFN, not the other way around.  While it would be nice to see them selling for 66c in a full reel, I suspect when the product info and pricing is all settled, the real (no pun intended) price will be closer to $1.
Revision B of the ATmega48PB/88PB/168PB Preliminary Summary and Complete data sheets are posted at Atmel AVR 8- and 32-bit Microcontrollers What's Changed.
Edit: It's interesting that the Summary errata sections of both A and B revisions are identical with the '88PB and '168PB Errata pages being pre-loaded with revisions B and C updates.
Stan
Total votes: 2
Now we have something to dig into. wink
From the first page summary:
-- No DIP package
-- Rated to 105 C
-- Power consumption numbers as noted earlier
Typical Characteristics, Active Supply Current chart:  1MHz, 5V:  PA ~0.8mA; PB ~0.62mA  <<less for PB
1.8V looks very close between the two charts at about 0.2--certainly not the 0.35 of the first page.
20MHz 5V is 9+mA for PA and 12+mA for PB -- indeed about 30% more?  Taking another point, 3.6V/10MHz is also 3mA for PA and 4mA for PB -- consistent.
"Sleep Modes" chart has added the USART (start-frame detection) column, and indicates it is applicable to all sleep modes.  However, the text says "The USART start frame detector can wake up the MCU from Power-down, Standby or ADC Noise Reduction sleep mode when it detects a start bit."
"VINT Internal Voltage Reference 1.0 1.1 1.2 V"
Same for both?!?  Not according to press release...
"Table 30-3. Calibration Accuracy of Internal RC Oscillator"
appears identical in both.  Not according to press release?
[If I busted my butt to add an improved feature to this PB initiative, I'd make darned sure that the datasheet reflected my work.]
Watchdog oscillator changed--differently-shaped curve vs. temperature.
Internal oscillator charts indeed show a much flatter temperature response.  And OSCCAL has a much smaller discontinuity jump, and much more linear frequency w.r.t. OSCCAL value.
Total votes: 2
A-HA!  I thought I saw something about more I/O pins.  As on the Tiny48 family, four more (more-or-less) GP I/O are gained:
PE2/PE3 (ADC6/ADC7)
PE0/PE1  taking over a pair of VCC/GND; one has ACO
(no pin-change)
Comparing the Register Summary, I see the following differences:
-- Port E
-- ACO bit (ACOE bit in new ACSR0)
-- Device ID, in high I/O space (direct access!)  [but in the text the registers are called DIDR0, DIDR1, ... which is a conflict]
-- ADC6D and ADC7D added to DIDR0
Thank you for locating the data sheets.
Wow!
Thank you for pouring over the datasheet!
Atmel Corporation
AT06609: Differences between ATmega48/88/168 Variants and the New ATmega48/88/168PB
http://www.atmel.com/Images/Atmel-42374-Differences-between-ATmega48_88_168-variants-and-the-new%20ATmega48_88_168PB_APNote_AT06609.pdf
(183KB)
LOL--I did quite well comparing datasheets.
I notice that the DIDRn conflict has been resolved -- the document indicates DEVIDn for the register names.
Mouser now has this in-stock in QFP :
Mouser Electronics
All Products > Unclassified > Atmel > Atmel ATMEGA168PB-AU
http://www.mouser.com/ProductDetail/Atmel/ATMEGA168PB-AU/?qs=%2fha2pyFadugRfkp7lkJNLcdh4BypYuX8rs6cF%252bIsNoOB0yzsW6iROQ%3d%3d
If QFN then Digi-Key.
Thank you for the app note review.
Octopart hasn't caught up to  that yet.  DigiKey has both -AU and -MU.
We got a few -AU from DigiKey last month.  Put them into a '48 app.  Re-built, and it worked fine.  Called it a '168PA for build  and skipped the signature check during ISP, and worked fine.
Since then, CodeVision has released a version with full build and ISP support, which also works fine.
Datasheet update :
Atmel Corporation
ATmega168PB
http://www.atmel.com/devices/ATMEGA168PB.aspx
37.1 Rev.42176C – 03/2015
      1.   “Clock Characteristics” :
           Updated factory calibration accuracy from ±10% to ±3%in ”Calibrated Internal RC Oscillator Accuracy” on page 304.
      2.   “Errata” :
           Updated ”Errata ATmega48PB” on page 349, ”Errata ATmega88PB” on page 350 and ”Errata ATmega168PB” on
           page 351.
PA datasheet:  650 pages, 36MB
PB datasheet:  360 pages, 7MB
Does that mean we only get half the features?  Or no-one read half the words in the PA datasheet anyway, so they were removed?
[The Typical Characteristics section for the PB hasn't been fleshed out yet, accounting for the discrepancy.]
New at What's Changed  http://www.atmel.com/System/whats_changed.aspx?Products=010%20Atmel%20AVR%208-%20and%2032-bit%20Microcontrollers
AT12615: Getting Started with ATmega168PB
(file size: 875KB, 16 pages, revision A, updated: 03/2015)
This application note describes how to get started with the
Atmel ATmega168PB microcontroller and documents step by
step how to create a simple project in Atmel Studio 6.2.
More via "What's Changed" is a 32kB version :
Atmel Corporation
ATmega328PB
http://www.atmel.com/devices/ATMEGA328PB.aspx
Did not compare the datasheets :
mega328P  : http://www.atmel.com/images/Atmel-8271-8-bit-AVR-Microcontroller-ATmega48A-48PA-88A-88PA-168A-168PA-328-328P_datasheet_Complete.pdf
mega328PB : http://www.atmel.com/Images/Atmel-42397-8-bit-AVR-Microcontroller-ATmega328PB_Datasheet.pdf
An important difference is the mega328PB has "Hardware QTouch Acquisition" via " QTouch® Peripheral Touch Controller (PTC)".
PTC - UC3L has similar with one autonomous button.
No parts yet in-stock though there's an Xplained Mini for it : http://www.atmel.com/tools/MEGA328PB-XMINI.aspx in-stock at Digi-Key.
Edit : parts availability.
More from AVR "What's Changed" are updates :
Atmel AT08401: Getting Started with Atmel ATmega328PB
http://www.atmel.com/Images/Atmel-42482-Getting-Started-with-ATmega328PB_Application%20Note_AT08401.pdf
Atmel AT12615: Getting Started with ATmega168PB
http://www.atmel.com/Images/Atmel-42422-MCU-Getting-Started-with-ATmega168PB-AT12615_Application-Note.pdf
#PBs are available from RS right now.... :) and nice and cheap :)
???  They don't even have a listing for '328PB, do they?
Only the 168PBs, the 328 part is still nowhere to be seen.
only 48/88/168 as far as I can see...
Datasheet update :
Microchip Technology Inc
Microchip
Product Change Notification - SYST-06KPYO935
http://www.microchip.com/mymicrochip/NotificationDetails.aspx?pcn=SYST-06KPYO935
25 Aug 2017
Data Sheet - ATmega48PB/88PB/168PB - Complete Datasheet
(data sheet URL)
Description of Change:
8) Add Errata Rev. O for ATmega168PB.
9) Electrical Characteristics - DC Characteristics: AC Input Offset Voltage improvement
mega328PB third party boards :
Watterott electronic
Wattuino Pro Mini PB 5V/16MHz (ATmega328PB)
http://www.watterott.com/en/Wattuino-pro-mini-PB-5V-16MHz
Elektor
Elektor Uno R4
https://www.elektor.com/elektor-uno-r4
The successor to the popular Arduino Uno R3 has the new ATmega328PB micro with extra I/O for even more versatility!
Please add support for Elektor Uno R4 with ATmega328PB #64
by elektor-labs
https://github.com/platformio/platform-atmelavr/issues/64
Might be good--since mega328pB is in extremely short supply for a long time
From Microchip Direct:  Estimated Ship Date: 11-Dec-2017
All PB megaAVR are moving from two non-Microchip wafer fabs to one Microchip fab with the final PCN possibly the third week of this month.
Microchip
Product Change Notification - GBNG-06LXXH156
https://www.microchip.com/mymicrochip/NotificationDetails.aspx?pcn=GBNG-06LXXH156
11 Dec 2017
CCB 2856 Initial Notice: Qualification of Microchip Fabrication site (FAB 4) for selected Atmel products manufactured with the 59.91K process technology.
Reason for Change:
To improve on time delivery performance by qualifying Microchip Fabrication site (FAB 4)
mega328PB marketing in social media :
https://plus.google.com/+MicrochipTech/posts/ceeG4MZ7161
Second wafer fab has been successfully qualified for mega328PB :
Microchip
Product Change Notification - KSRA-05VVCD269
http://www.microchip.com/mymicrochip/NotificationDetails.aspx?pcn=KSRA-05VVCD269
30 Jan 2018
CCB 2995 Final Notice: Qualification of UMC5 as an additional fabrication site for Atmel ATMEGA328PB device families manufactured with the 59.91K process technology.
Post Change:
Fabricated at TPS5 and UMC5 fabrication sites
Fab Site
Post Change
TowerJazz Panasonic (TPS5)
United Microelectronics Corporation (UMC5)
Reason for Change:
To improve on time delivery performance by qualifying UMC5 as an additional fabrication site.
Estimated First Ship Date:
March 02, 2018 (date code: 1809)
Revision History:
September 06, 2017: Issued initial notification.
January 22, 2018: Issued final notification. Attached the Qualification Report. Provided estimated first ship date to be on March 02, 2018.
Second wafer fab has been successfully qualified for mega324PB :
Product Change Notification - KSRA-27RHHN879 - 17 Apr 2018 - CCB 2994 Final Notice: Qualification of UMC5 as an additional fabrication site for Atmel ATMEGA324PB device family manufactured with the 59.91K process technology.
http://www.microchip.com/mymicrochip/NotificationDetails.aspx?pcn=KSRA-27RHHN879
May 17, 2018 (date code: 1820)
All PB megaAVR wafer fabrication will be moved to Microchip.
Product Change Notification - GBNG-06LXXH156 - 02 May 2018 - CCB 2856 Final Notice: Qualification of Microchip Fabrication site (FAB 4) for selected Atmel products manufactured with the 59.91K process technology.
http://www.microchip.com/mymicrochip/NotificationDetails.aspx?pcn=GBNG-06LXXH156
June 2, 2018 (date code: 1822)
Better order mine now!!  They tend to forget plugging in the machines. cheeky
wink
The prices will slowly decrease assuming we don't have to endure the same old same old (recession)
Have read that the price of 8-inch wafers has increased.
mega328PB is approaching 1USD each (quantity 100)
megaAVR 0-series is close in price.
Electronics Sourcing
Expect Less Price Erosion For MCUs
by James Carbone
April 30, 2018
http://www.electronics-sourcing.com/2018/04/30/expect-less-price-erosion-for-mcus-by-james-carbone/
“Less torrid” growth
Microchip derives about 62 per cent of its total revenue from microcontroller sales.
“Smart card MCUs comprised over 50 per cent of the total MCU units in 2017. Last year there was a boom in smart cards,” - Jim Feldhan, Semico Research
[my comment is USA banks finally matched EU banks by replacing magnetic stripe-only credit/debit cards with smart cards]
“More than 30 per cent of MCUs go to automotive. It’s a huge part of the market,” said Feldhan.
Demand grows for 32-bit MCUs
8-bit accounts for about 31 per cent of unit shipments and 17 per cent of revenue, the researcher said. [Semico Research]
New systems that require ultra-low cost, low-power 8-bit and 16-bit solutions continue to be designed.
The main purpose for MCUs has always been for embedded simple applications. “While they may not be capturing the highest growth, these 8-bit and 16-bit solutions are still highly competitive when energy-efficiency, price and area are still the primary considerations,” said [Tom] Hackenberg [principal analyst, IHS Markit].
[Semico Research, pie chart, revenue by MCU bit-width]
http://new.microchipdirect.com/product/search/all/ATmega328PB
http://new.microchipdirect.com/product/search/all/ATmega3208
Product Change Notification - GBNG-06LXXH156 - 25 Jun 2018 - CCB 2856 Final Notice: Qualification of Microchip Fabrication site (FAB 4) for selected Atmel products manufactured with the 59.91K process technology.
Revision History:
June 25, 2018: Re-issued final notification. Revised the affected parts list.
Elektor Uno R4 is out of stock though ...
GroupGets
Elektor Uno R4
https://groupgets.com/campaigns/451-elektor-uno-r4
Why GroupGet?
We have produced this board in the past but now that it is sold out we are hesitating to do another batch. If there are enough people interested we will launch a new batch.
Availability
Campaign active, scheduled end date: Sun, 30 Sep 2018 00:18:00 -0700
Factory Lead Time
Eight weeks
Shipping Details
GroupGets will handle the shipment of orders for this product.
via https://plus.google.com/u/0/106109247591403112418/posts/c397T9Fjafg
Edit : via
Product Change Notification - SYST-17QMUV125 - 23 Aug 2018 - Data Sheet - ATmega328PB Automotive - Complete Data Sheet
http://www.microchip.com/mymicrochip/NotificationDetails.aspx?pcn=SYST-17QMUV125
1.)
Updated Absolute Max. Ratings table
2.) Remove 'Preliminary' for the data sheet;
3.) Other minor corrections.
https://www.microchip.com/wwwproducts/en/ATMEGA328PB-AUTOMOTIVE
Microchip Thailand will be the second assembly site for PB megaAVR in TQFP-32 at MSL 1 (unlimited floor life at elevated relative humidity and warm room temperature)
Product Change Notification - KSRA-20BGKY389 - 23 Dec 2019 - CCB 4023.001 and 4023.002 Initial Notice: Qualification of MTAI as an additional assembly site for selected Atmel products available in 32L (7x7x1.0mm) and 48L TQFP (7x7x1.0mm) package using gold (Au) wire.
Estimated Qualification Completion Date:
January 2020
Product Change Notification - GBNG-15DMKA648 - 20 Apr 2020 - CCB 2856.001 Final Notice: Qualification of an additional fabrication site (Microchip – FAB 4) for selected Atmel automotive products available in 28L SSOP, 32L, 44L, 48L TQFP and 20L, 24L, 32L, 44L VQFN packages.
June 05, 2020 (date code: 2023)
Revision History:
April 20, 2020: Issued final notification.
includes unified-memory AVR from tinyAVR 1-series and megaAVR 0-series
wafer FAB 4 is in Gresham, Oregon :
https://careers.microchip.com/jobsearch/#All~Job~Categories|US+OR+Gresham||d-ASC|1
Microchip Thailand will be the assembly site for mega328PB in QFN MSL 1.
Microchip Thailand will be the second assembly site for mega48PB, mega88PB, and mega168PB in QFN MSL 1.
GBNG-20XTKS327 | Product Change Notification | Microchip
Qualification of MMT as an additional assembly site for selected Atmel products available in 32L VQFN (5x5x0.9mm) package with MSL 1 classification.
November 15, 2020 (date code: 2047)
Revision History:
November 3, 2020: Issued final notification. Attached the Qualification Report. Provided estimated first ship date to be on November 15, 2020.
