Wainwright Solder-Mount/Mini-Mount prototyping system
6 posts / 0 new
Does anyone remember the Wainwright Solder-Mount/Mini-Mount prototyping system? The product was discontinued in 2006. I am looking for a pdf of the catalog that was on their website to use as a starting point to create my own library of parts with Kicad.
http://www.adventure-radio.org/ars/images/backissue_images/2000_images/1200_images/solder_mount.jpg
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtaWSO6CFCQuBBh_xDOMTnYUOUy-KvD_Ika3Ddnkuq2AWV9CQO
Rick
Have you tried putting your images into Google Image Search ... ?
I am quite confident I have looked at every image that uses the solder mount parts. Searching for the first image returns this. http://www.google.com/imgres?imgurl=https://www.avrfreaks.net/sites/default/files/AVRFreaksLogos2.png&imgrefurl=https://www.avrfreaks.net/forum/wainwright-solder-mountmini-mount-prototyping-system&h=117&w=317&tbnid=_ydJl8jNBa560M:&docid=TAE1LH8B79Xo-M&itg=1&hl=en&ei=uajbVcqgM42vogTH7LmQDw&tbm=isch&ved=0CB0QMygAMABqFQoTCIrhttrvwscCFY2XiAodR3YO8g&biw=707&bih=594
Not very accurate. I think it matched the image to the teeth or the eyes.
I'm not looking for random examples. What I want is the catalog (pdf).
Maybe your GoogleFu is better.
Rick
Did you try the internet wayback machine, google that and see if they have a copy of what you need.
Jim:
I had forgotten about that. Unfortunately all but 1 page is missing the images of the pad layouts. I checked several years worth of archives and found that only page 11 has images. Very strange. Bummer.
Rick
These look to be just basic footprints, but with just 1 device on each little board - no?
Rather like the little breakout/adaptor boards that you can buy; eg,
9081 Capital Advanced Technologies | 9081CA-ND DigiKey Electronics 9162 Capital Advanced Technologies | 9162CA-ND DigiKey Electronics1230 Adafruit Industries LLC | 1528-1072-ND DigiKey Electronics
http://www.digikey.co.uk/product...
So I'm not really seeing how this catalogue helps - can't you just take standard footprints from standard libraries?
Or am I just being thick?
