Tag-Connect
8 posts / 0 new
Was thinking about getting one of these for occasional after construction re-programming...
http://www.tag-connect.com/
Any one got one? Good/bad/is there something else equivalent?
Any ideas for connecting the RJ-12 to something more "AVR" - or just cut it off and rewire to an ISP 6-pin connector?
I guess not then?
Any one got one?
You seem to have guessed right. :) But I know of someone thinkering with the idea of something similar. It may even be the same cable. (not me by the way)
Tag-Connect now sell the TC2030-IDC Plug-of-Nails cable which is exactly what you need with a 6-pin ribbon conector. You can purchase it on the Tag-Connect website.
MartinM57 wrote:
I guess not then?
I have now: https://www.avrfreaks.net/comment...
I have two.
They seem to work OK.
There are several active threads on the topic of ISP connectors, and these are often suggested.
I had one that worked great with my AVRISP mkii.
Got one to work w/ the Atmel-ICE, and had somewhat less success....
Science is not consensus. Science is numbers.
