Chip ID
3 posts / 0 new
Perhaps I just haven't RTFMd enough yet.
Is there a unique ID in each of the chips? I've found where you can tell what kind of chip it is. I'm thinking of the xMega where it has 11 bytes uniquely identifying each chip by lot number, wafer number, x and y position on the wafer...
In my humble opinion, I'm always right.
The SAM4S Series datasheet happens to be in my Adobe Reader's recently used list:
8.1.3.7 Unique Identifier
Each device integrates its own 128-bit unique identifier. These bits are factory-configured and cannot be changed
by the user. The ERASE pin has no effect on the unique identifier.
Oh. Cool.
Thanks.
