a better way of receiving data through UART
6 posts / 0 new
hello avrfreaks,
please have a look at this function for receiving data through UART that i have written:
unsigned char UARTRx()
 unsigned char ch;
 while(Rxread1==Rxwrite1);
 ch=Rxbuffer[Rxread1];
 Rxbuffer[Rxread1++]='\0';
 if(Rxread1==BUFFER_SIZE) Rxread1=0;
 return ch;
is there any better way to read data from the UART?
i should mention that i am using c.
any suggestions are greatly appreciated.
Long live my MASTER.
I like the "lightweight ring buffer" code from Dean Camera as a part of LUFA:
http://www.fourwalledcubicle.com... (doc)
http://www.fourwalledcubicle.com... (code - yup, it's all in this .h file)
While the read_ptr==write_ptr is one way to check for "nothing in the buffer" I think a lot of people would favour a ring buffer that also keeps a count of how many bytes are in the buffer (because a full buffer can also look like read==write otherwise!). Then the wait simply becomes "while(bytes_in_buffer() == 0);"
That doesn't actually have anything to do with the UART at all - it's just reading from your software ring buffer!
One optimisation is to ensure that the size is a power of 2 ...
thanks a lot.
While the read_ptr==write_ptr is one way to check for "nothing in the buffer" ...
Unless the app does >>nothing<< but process incoming characters from the UART, that is a "blocking read" function and will sit there forever waiting for the next character to arrive.  No display updates; no button press recognition; no servicing of external chips; ...
IMO/IME not much use in a "real" microcontroller app, unless there is indeed a way to "peek" to be sure there is something in the buffer before invoking the getchar.
real firmware uses interrupts and a ringbuffer :)
Then getchar return false if the rb is empty
Keith Vasilakes
Firmware engineer
Minnesota
