how to compare a macro with a constant?
8 posts / 0 new
is there any way of comparing (using relational operators with) a macro with a constant value?
i have defined a macro in my program, the macro is a system variable whose values could be changed later on as per our requirements (like the F_CPU), and now need to check for its values for further logic designing. i am trying to use the same procedure of using relational operators as is done with any variable. but that doesn't seems to work and the compiler is showing errors.
how can one achieve such an objective?
thank you for the replies.
Long live my MASTER.
Your question is too vague - you haven't even said what language you're using!
In 'C', a macro is just a compile-time text substitution (actually, just before the actual compilation - hence "pre-processor").
Check your compiler manual to find out how to see the preprocessor output; for GCC, it's -save-temps
When you look at the preprocessor output, you see the text that the actual compilation process sees - you will see how your macro expands and it should then be obvious where you're going wrong ...
http://www.8052.com/forum/read/2...
https://www.avrfreaks.net/comment...
I was just looking at an example (AVR-LibC's <avr/fuse.h>) this morning for another thread so will cite that here as it shows a good use of conditional operators in macros checking against numeric constants:
#if FUSE_MEMORY_SIZE > 3
typedef struct
    unsigned char byte[FUSE_MEMORY_SIZE];
} __fuse_t;
#elif FUSE_MEMORY_SIZE == 3
typedef struct
    unsigned char low;
    unsigned char high;
    unsigned char extended;
} __fuse_t;
#elif FUSE_MEMORY_SIZE == 2
typedef struct
    unsigned char low;
    unsigned char high;
} __fuse_t;
#endif
Each AVR device header the contains something like:
#define FUSE_MEMORY_SIZE 6
#define FUSE_MEMORY_SIZE 3
#define FUSE_MEMORY_SIZE 2
or whatever.
ok
so we need to use #if, #elif, #else and #endif directives.
there i was going wrong.
 thank you very much
 and....i am using c.
Not necessarily.
Only if you want to control Conditional Compilation.
As I said before, macros are just text replacements - so the macros can be used anywhere that their is expansion is valid
eg,
if( F_CPU == 0 )
    printf( "That's not right!!" );
or, as clawson showed,
typedef struct
} __fuse_t;
Btw after Andy's last comment be very careful to understand the difference between:
#if F_CPU == 8000000
 delay_ms(50);
#else
 // too slow, no delay
#endif
and
if (F_CPU == 8000000) {
    delay_ms(50);
After the C preprocessor has run in each case what the C compiler actually gets to see in each case (for F_CPU = 8000000) is:
 delay_ms(50);
or
if (8000000 == 8000000) {
    delay_ms(50);
That is the F_CPU and #if/#else sections are just text substitutions.
Note that, when the compiler sees:
    delay_ms(50);
it will almost certainly realise that the 'if' condition never changes and can never be false - so it will actually implement it as just
    delay_ms(50);
ok, got ti.
thanks a lot.
