PSDU data rate vs data rate
3 posts / 0 new
Hi
The datasheet for part AT86RF212B says:
"O-QPSK with... 1000kb/s PSDU data rate".
Is it possible to achieve overall 1000kb/s data rate?
I tried to research "PSDU data rate", but I'm only seeing references to TCP chips, which this isn't, so I'm confused.
My application is streaming audio.
Thx
If you look in the datasheet, you will find a diagram showing the PSDU structure - that will show you how much of a PSDU is "payload" and how much is "overhead"...
No, it is not possible. In a peer2peer mode with CSMA/CA, ACKs and retries disabled you can get around 800 kbps. And that's basically as close to 1 Mbps as you will get.
