Tiny167: AVRDUDE vs 16K program memory
3 posts / 0 new
For the last few weeks I've been troubleshooting an issue with my Tiny167-based board. Today I finally traced it to what I believe is a bug either with my FTDI-based programmer or AVRDUDE which is driving it.
I've tried my old standby of a V5.x of AVRDude on Windows... and tried running AVRDude 6.1 from Linux. The problem persists.
The issue I'm seeing AVRDude dosn't support the tiny167 (16k flash)... So I'm using a CFG posted by someone on the interwebs posted a config file update since there is no "official" config w/ tiny167 in it.
When I program the device; it fails at verification for a specific address. When I look at the device dump it's pretty clear than the bootloader is being placed at the end of 0x1fff instead of 0x3fff. IE 8k vs 16k.
Has anyone been able to program a Tiny167 w/ AVRDude?
Suggestions?
But where did you tell the linker to put the bootloader?
Perhaps post a piece of the .HEX file that includes the bootloader.  Those 'Freaks that are Lord of the Rings fans may also like to see the .ELF, if GCC is being used.
"Today, I finally traced it to what I believe is a bug either with my FTDI-based programmer or AVRDUDE which is driving it.  ..."
Isn't that supposed to end with "FML"? ;)  http://www.fmylife.com/
I got it. I hacked around in the conf file... using the Mega16 as a guide. This appears to work properly.
I added a12 and a13 to the readhi, readlo, and writepage entries of flash"
# ATtiny167
part
     id            = "t167";
     desc          = "ATtiny167";
     has_debugwire = yes;
     flash_instr   = 0xB6, 0x01, 0x11;
     eeprom_instr  = 0xBD, 0xF2, 0xBD, 0xE1, 0xBB, 0xCF, 0xB4,
               0x00, 0xBE, 0x01, 0xB6, 0x01, 0xBC, 0x00, 0xBB,
               0xBF, 0x99, 0xF9, 0xBB, 0xAF;
## no STK500 devcode in XML file, use the ATtiny45 one
     stk500_devcode   = 0x14;
##  avr910_devcode   = ?;
##  Try the AT90S2313 devcode:
     avr910_devcode   = 0x20;
     signature        = 0x1e 0x94 0x87;
     reset            = io;
     chip_erase_delay = 1000;
     pgm_enable       = "1 0 1 0  1 1 0 0    0 1 0 1  0 0 1 1",
                        "x x x x  x x x x    x x x x  x x x x";
     chip_erase       = "1 0 1 0  1 1 0 0    1 0 0 x  x x x x",
    timeout  = 200;
    stabdelay  = 100;
    cmdexedelay  = 25;
    synchloops  = 32;
    bytedelay  = 0;
    pollindex  = 3;
    pollvalue  = 0x53;
    predelay  = 1;
    postdelay  = 1;
    pollmethod  = 0;
    pp_controlstack     =
    0x0E, 0x1E, 0x0E, 0x1E, 0x2E, 0x3E, 0x2E, 0x3E,
    0x4E, 0x5E, 0x4E, 0x5E, 0x6E, 0x7E, 0x6E, 0x7E,
    0x06, 0x16, 0x46, 0x56, 0x0A, 0x1A, 0x4A, 0x5A,
    0x1E, 0x7C, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00;
    hventerstabdelay    = 100;
    progmodedelay       = 0;
    latchcycles         = 5;
    togglevtg           = 1;
    poweroffdelay       = 20;
    resetdelayms        = 1;
    resetdelayus        = 0;
    hvleavestabdelay    = 15;
    chiperasepulsewidth = 0;
    chiperasepolltimeout = 10;
    programfusepulsewidth = 0;
    programfusepolltimeout = 5;
    programlockpulsewidth = 0;
    programlockpolltimeout = 5;
    idr                 = 0x00;
    spmcr               = 0x57;
    allowfullpagebitstream = no;
     memory "eeprom"
         size            = 512;
        paged           = no;
        page_size       = 4;
         min_write_delay = 4000;
         max_write_delay = 4500;
         readback_p1     = 0xff;
         readback_p2     = 0xff;
         read            = "1  0  1  0   0  0  0  0    0 0 x x  x x x a8",
                           "a7 a6 a5 a4  a3 a2 a1 a0   o o o o  o o o o";
         write           = "1  1  0  0   0  0  0  0    0 0 x x  x x x a8",
                           "a8 a6 a5 a4  a3 a2 a1 a0   i i i i  i i i i";
 loadpage_lo = "  1   1   0   0      0   0   0   1",
     "  0   0   0   0      0   0   0   0",
     "  0   0   0   0      0   0  a1  a0",
     "  i   i   i   i      i   i   i   i";
 writepage = "  1   1   0   0      0   0   1   0",
     "  0   0   x   x      x   x   x   x",
     "  0   0  a5  a4     a3  a2   0   0",
     "  x   x   x   x      x   x   x   x";
 mode  = 0x41;
 delay  = 10;
 blocksize = 4;
 readsize = 256;
     memory "flash"
         paged           = yes;
         size            = 16384;
         page_size       = 128;
         num_pages       = 128;
         min_write_delay = 4500;
         readback_p1     = 0xff;
         readback_p2     = 0xff;
         read_lo         = "  0   0   1   0    0   0   0   0",
                           "  0   0  a13 a12  a11 a10  a9  a8",
                           " a7  a6  a5  a4   a3  a2   a1  a0",
                           "  o   o   o   o    o   o   o   o";
         read_hi         = "  0   0   1   0    1   0   0   0",
                           "  o   o   o   o    o   o   o   o";
         loadpage_lo     = "  0   1   0   0    0   0   0   0",
                           "  0   0   0   x    x   x   x   x",
                           "  x   x  a5  a4   a3  a2  a1  a0",
                           "  i   i   i   i    i   i   i   i";
         loadpage_hi     = "  0   1   0   0    1   0   0   0",
                           "  0   0   0   x    x   x   x   x",
                           "  i   i   i   i    i   i   i   i";
         writepage       = "  0  1  0  0   1   1   0  0",
                           " a7 a6  x  x   x  x  x  x",
                           "  x  x  x  x   x  x  x  x";
 mode  = 0x41;
 delay  = 10;
 blocksize = 64;
 readsize = 256;
#   ATtiny167 has Signature Bytes: 0x1E 0x94 0x87.
     memory "signature"
         size            = 3;
         read            = "0  0  1  1   0  0  0  0   0  0  0  x   x  x  x  x",
                           "x  x  x  x   x  x a1 a0   o  o  o  o   o  o  o  o";
     memory "lock"
         size            = 1;
         write           = "1 0 1 0  1 1 0 0  1 1 1 x  x x x x",
                           "x x x x  x x x x  x x x x  x x i i";
         read            = "0 1 0 1  1 0 0 0  0 0 0 0  0 0 0 0",
                           "0 0 0 0  0 0 0 0  o o o o  o o o o";
        min_write_delay = 9000;
        max_write_delay = 9000;
     memory "lfuse"
         size            = 1;
         write           = "1 0 1 0  1 1 0 0  1 0 1 0  0 0 0 0",
                           "x x x x  x x x x  i i i i  i i i i";
         read            = "0 1 0 1  0 0 0 0  0 0 0 0  0 0 0 0",
                           "x x x x  x x x x  o o o o  o o o o";
     memory "hfuse"
         size            = 1;
         write           = "1 0 1 0  1 1 0 0  1 0 1 0  1 0 0 0",
         read            = "0 1 0 1  1 0 0 0  0 0 0 0  1 0 0 0",
     memory "efuse"
         size            = 1;
         write           = "1 0 1 0  1 1 0 0  1 0 1 0  0 1 0 0",
                           "x x x x  x x x x  x x x x  x x x i";
         read            = "0 1 0 1  0 0 0 0  0 0 0 0  1 0 0 0",
     memory "calibration"
         size            = 1;
         read            = "0  0  1  1   1  0  0  0    0 0 0 x  x x x x",
                           "0  0  0  0   0  0  0  a0   o o o o  o o o o";
