8x8 LED question regarding loading the ports/pins with hex values
4 posts / 0 new
I've discovered that certain pins control certain columns on the matrix. Most of the example programs I've seen have for loop that use something like "displaywrite([column][code])
The way I have the code below set up, it is writing to the entire port the hex value. How would I go about getting that hex value onto each column so that it will actually display the image?
#include <util/delay.h>
#define BLINK_DELAY_MS 1000
int main (void)
	DDRB |= 0xFF;		// everbody output!
	DDRD |= 0xFF;
	DDRC |= 0xff;
while(1) {
  /* set pin 5 high to turn led on */
  PORTB |= _BV(PORTB5);
  //PORTB |= _BV(PORTB3);
  //PORTD |= _BV(PORTD6);
  //PORTB |= _BV(PORTB2);
  //PORTD |= _BV(PORTD3);
  //PORTC |= _BV(PORTC3);		/* set pin 3 of portC for output arduino pin A3*/
  //PORTD |= _BV(PORTD4);		/* set pin 4 of PORTD for output arduino pin 4*/
  //PORTB |= _BV(PORTB0);   		/* set pin 0 of PORTB for output arduino pin 8*/
  //PORTB |= _BV(PORTB1);
  //column
/*  PORTD |= _BV(PORTD2);  //col8
  PORTD |= _BV(PORTD7);  //col7
  PORTC |= _BV(PORTC5);  //col6
  PORTD |= _BV(PORTD5);  //col5
  PORTB |= _BV(PORTB5);  //col4
  PORTC |= _BV(PORTC4);  //col3
  PORTB |= _BV(PORTB4);  //col2
  PORTC |= _BV(PORTC2);  //col1
  PORTD |= _BV(0x00);  //col8
  PORTD |= _BV(0x18);  //col7
  PORTC |= _BV(0x3C);  //col6
  PORTD |= _BV(0x7E);  //col5
  PORTB |= _BV(0xFF);  //col4
  PORTC |= _BV(0xFF);  //col3
  PORTB |= _BV(0x66);  //col2
  PORTC |= _BV(0x00);  //col1
//how to draw heart
//unsigned char row_val[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
//unsigned char col_val[8]={0x00,0x66,0xff,0xff,0x7e,0x3c,0x18,0x00};
Do you realise that
_BV(0x3C)
is nonsense? After the substitution there will be 1<<0x3C and it is far more than int resolution so it is just 0
Anyway, if you have for example whole PORTC as columns with npn transistors and PORTD as rows:
for (uint8_t mask=1, i=0; i<8; ++i,mask<<=1) {
    PORTC = mask;
    PORTD = image[i];
    _delay_ms(2);
    PORTC = 0;
    // delay for full turn off of transistor ?
Or even better to have timer interrupt to switch rows and displaying data without _delay_ms()
Computers don't make errors - What they do they do on purpose.
You could have continued with this one or edited this one https://www.avrfreaks.net/forum/m...
Perhaps moderator will lock other one.
No transistors, just resitsors.
I have it hooked like the attached picture.
