Failed to open com
6 posts / 0 new
I am getting a failed to open \\.\com18 Error 0x2.
My setup is my own board design, Atmel 6.2 sp2, a pololu avr programmer on a W7 laptop plugged into a docking station.
I can connect to the board & I can program and verify the code.
Then when I want to begin debugging and go to the tools selection drop down at the top of Atmel Studio, 'Attach to Target' is grayed out.  If I click on Start Debugging and Break, it builds the program without error but then gets the failure to open com error.
Why is the 'Attach to Target" grayed out?
Why do I get a com error when I can program the device successfully?
Thanks.
You have a programmer, not a debugger so that's why you are getting the error
Doh!!!!!
Thanks.
Can I install gdb with atmel Studio 6.2 and debug that way?  Or do I need another piece of hardware in order to use it?
thanks again.
YOu need any of the following to perform debugging:
Dragon)old)
JTAG-ICEMKII(old)
JTAGICE3
Atmel-ICE(best bet)
Dragon)old)
JTAG-ICEMKII(old)
JTAGICE3
Atmel-ICE(best bet)
Or a board with a built-in debug probe - such as the Xplained Pro or Xplained Mini
As this is not a device-specific section of the forum, and no specific device has been mentioned, we could add that 3rd-party debug probes are available (at least for the ARM-based parts); eg,
  • Segger J-Link (works with Atmel Studio & 3rd-party software);
  • Keil uLink (only works with Keil).
Note that the Atmel-ICE is just a badged Segger J-Link.
Thanks a lot for taking the time to respond and supplying more info than I requested.
