AVR Bootloader over bluetooth SPP
3 posts / 0 new
Hi Everyone,
Is it possible to program a Mega128 over bluetooth SPP?
i have a board with a Bluetooth HC06  connected to USART0 of the mega128. I was thinking of using a bootloader so i can program the target without opening up the system. Can i bypass the physical reset using a routine to reset the target using the WDT.
Which bootloader would you Suggest,
Regards
Rodney Almeida
With HC-05 it would be much easier, as there is possibility to switch polarity for second led that indicates connection - if it is connected to the reset pin through cap, it will reset avr. http://letsmakerobots.com/content/programming-arduino-bluetooth
But HC-06 is little bit more complicated, as there is just one led - however some 74HC123 with correct timeout would do the trick (with about more than 800ms delay).
And then you can use standard bootloader.
Computers don't make errors - What they do they do on purpose.
Yes.
Adafruit
Adafruit Learning System
Introducing Bluefruit EZ-Link Breakout
Overview
https://learn.adafruit.com/introducing-bluefruit-ez-link/overview
The Bluefruit EZ-Link is a regular 'SPP' serial link client device, that can pair with any computer or tablet and appear as a serial/COM port (except iOS as iOS does not permit SPP pairing).
Every other Bluetooth SPP device we've ever seen, if they even have the RTS/DTR pins brought out, do not sync back to the computer, instead the flow control is for the module serial buffer itself.
Probably Optiboot.
https://github.com/arduino/Arduino/tree/master/hardware/arduino/avr/bootloaders
