precompiler arithmatic ^ (power) operator
5 posts / 0 new
I have been searching all through freaks.net and google for anything on this with no luck.
I know that the + - * and / operators work in #define statements, I thought that the ^(power) operator worked also. Evidently I'm wrong
#define GOOBER (2^8)
evaluates to 10. Wouldn't be a big deal, but for actual use the 8 is replaced with a nother constant. I could calculate these everytime I adjust something, but I like having a tidy code that's easy to tweek.
My question: Is there a way to use the power operator in the precompiler to calculate constants?
Ben
^ is the exclusive or operator. If you need powers of two then bit shifting works fine (1 << n) is 2 to n:th power.
/Lars
Hi Ben,
the ^ operator is allready used for exclusive-OR bit-operation.
Using it for power operator would be at least confusing and I think not possible because it would define a second meaning for the ^ operator.
In other compilers I have seen that a power() function is available. Have not seen (or needed) that in the WINAVR GCC package.
good luck. EAP
You need to go back to your basic 'C' textbook.
Very wrong.
'^' is not the "power" operator in the 'C' programming language. Never has been!
In fact, they don't actually do anything at all in #define "statements"
#define GOOBER ( 2^8 )
just makes the preprocessor replace every occurrence of the text "GOOBER" with the text "( 2^8 )" - the preprocessor does not actually do any arithmetic at all here!
(the compiler probably evaluates the expression at compile time, but not the preprocessor)
