Replacements for original ZigBit Modules running LWMESH
8 posts / 0 new
Atmel are replacing the original Zigbit modules with a range of new ones. They are bigger and about 3x the price, most have chip antennas.
We use the original modules -24 and -900 with external antennas. We can use LwMesh in 784Mhz, 868Mhz, 915Mhz and 2.4Ghz bands with a single footprint module. The new modules have gone in a different direction and this is now not possible.
The only solutions I can see are :-
1) Produce our own modules or put the chips direct onto the pcb.
2) Use the new MCU-less modules and port the stack onto the existing non Atmel MCU. But this may not be allowed by the LwMesh license.
Any other solutions anyone ?
I guess you could search for other manufacturers making compatible modules?
A few people seem to be building SAM R21 based stuff ...
The standard licence prohibits use on non-Atmel MCUs
But I guess you could contact Atmel, explaining your predicament, and see what they say...
Probably the cleanest solution. Base them on R21 and you have a good module that you may even sell.
This is not really clear. You are buying at least one Atmel product here, and the real attraction of the MCU-less module is software. It would be strange to prohibit running the software in this case, so I would definitely ask.
and I might even buy!
wink
You are buying at least one Atmel product here ... It would be strange to prohibit running the software in this case
Indeed!
That was essentially my question in https://www.avrfreaks.net/comment... - so would be interesting to know how you get on ...
awneil wrote:
Indeed!
Interestingly, the BitCloud Zigbee Pro licence says,
Atmel grants Developer a non-exclusive, limited license:
(a) to use the Software as a development platform solely in connection with an Atmel product ("Atmel Product"),
So, as long as you use "an Atmel product", you can use BitCloud - it doesn't require that it's either an Atmel MCU or an Atmel radio!?
Total votes: 2
BitCloud had a closed library, so running it on any other MCU is technically impossible.
I see!
