op amp 36V supply with NULL pins
8 posts / 0 new
Dear freaks,
I am searching for a general purpose op amp with a 32V (max) power supply and nulling pins.
Can you help ?
Michael.
User of:
IAR Embedded Workbench C/C++ Compiler
Altium Designer
Single rail supply?
If so, options include the mc34071 from onsemi and op90 from analog. The lt1006 from linear might also work.
- S
What's it for?
Knowing the application might open-up some application-specific suggestions ...
http://www.catb.org/esr/faqs/sma...
Thank you all .
regards
Michael.
User of:
Altium Designer
"One's value is inherent; money is not inherent"
Chuck, you are in my heart!
Any old +-15V opamp has +-18V rails max,so it can run no prob from maybe 35V single supply. Need to bias the + input correctly. Harris made +-35V opamps that showed up in a lot of MCI studio mixing boards. Lots of headroom compared to +-15V swing. Still avail, but I forgot who bought them... How's the automotive project progressing? Kartman has convinced me that Freescale LIN bus alternator chips are alive and out there.
Op-amps don't have ground pins. So when you say 32 V max power supply, that means that you can use split rails of +/- 16 V or you can set the negative rail to 0 V and the positive rail to 32 V, or any weird combination you like, and it will work.
Since many common op-amps are on a 36 V process -- meaning it's common to run them at +/- 15 V but they'll work to +/- 18 V -- you have a big list.
In fact, the bog-standard 29-cent NE5534A single has a power supply range of +/- 20 V and it has compensation pins.
-a
I have two '65 bassman heads and 3 twin 12 cabs.
