Connecting 3,3V uC and sim900 4V
4 posts / 0 new
Hi !
I have uC  which runs on 3,3V but could also handle 3,6V.
Sim900 runs from 3,6-4,5V.  When transmitting voltage drops for about 0,4V, so sim900 should have at least 4,0V.
Connection between uC and sim900 is serial and what I need is voltage level translator  3,3V <=> 4V.
Thank you !
Best regards !
The SIM900 PDF says supply voltage 3.4V - 4.5V
So you could run SIM900 and MCU @ 3.4V
If you are determined to use 4.0V and 3.3V you can use series resistors to cope with level-translation.
Both I2C and SPI will work quite happily with hi=3.3V on the 4.0V device.
You could use buffer chips but it is hardly worth it.    But they would be preferable if you want minimum current from a battery.
I have the same issue , can i continue this discussion or start a new one?
while(!solution) {patience--;}
