SPI Problem AT32UC3B164
6 posts / 0 new
I have an SPI code, which works fine with AT32UC3B0256 on EVK1101. I've built my own board with the AT32UC3B164, and the problem that I see is that MOSI stays high. The CS and CLK are present. The MOSI is showing some ripples when it supposed to send the data. I measured the resistance between VCC and MOSI and GND and MOSI on both boards, and it's the same, 100K. Is there something that I'm missing.
Thanks for all help.
Is the MOSI pin on your board the same as what is on the EVK1101 ?
ie. check the GPIO multiplexing.
Yes, the GPIO multiplexing is the same. I've even replaced the AT32UC3B164 microcontroller on my board, but there are still same results. While the chip was removed, I used CLK, MOSI, CS from the EVK1101, and the board worked fine. Is there anything else that I should check?
If the SPI pins are the same and the firmware is the same then it seems to me to be a power problem.
Are all the VDDIO, VDDCORE, etc pins connected and have power on them ?
I've checked all the voltages, and they're present on the board. All the pin connections are made according to the datasheet.
What I meant was, are *all* 3 VDDIO pins connected to 3.x volts, and the 3x VDDCORE pins connected to VDDOUT (or 1.8V) ?
