error: undefined reference to function call
7 posts / 0 new
Hi all,
I am having a few header problems. When I declare setup(); in main.c, the functions in main.c cannot see the header files in .h file.
These are the errors I am getting when compiling. Can you see any obvious things I have missed?
I am currently using Amtel Studio 6.2 and the ATmega328P.
error 1) undefined reference to `assign_channel'
error 2) undefined reference to `write_single_byte'
error 3) undefined reference to `write_single_byte'
error 4) undefined reference to `initialize_serial'
error 5) undefined reference to `initialize_spi'
error 6) undefined reference to `convert_channel'
error 7) undefined reference to `read_voltage_or_resistance_results'
error 8 ) undefined reference to `read_temperature_results'
Below is main.c and the .h file.
Many Thanks, Tuurbo46
// main.c
#include <stdint.h>
#include <stdbool.h>
#include "stdio.h"
#include "math.h"
#include "LTC2983_configuration_constants.h"
#include "LTC2983_support_functions.h"
#include "LTC2983_table_coeffs.h"
typedef signed char  byte;
typedef int          boolean;
// Function prototypes
void configure_channels();
void configure_global_parameters();
// -------------- Configure the LTC2983 -------------------------------
void setup() {
	initialize_serial();
	initialize_spi();
void configure_channels() {
	byte channel_number;
	long channel_assignment_data;
	// ----- Channel 1: Assign RTD PT-100 -----
	channel_assignment_data =
	(long) SENSOR_TYPE__RTD_PT_100 |
	(long) RTD_RSENSE_CHANNEL__NONE |
	(long) RTD_NUM_WIRES__4_WIRE |
	(long) RTD_EXCITATION_MODE__ROTATION_SHARING |
	(long) RTD_EXCITATION_CURRENT__5UA |
	(long) RTD_STANDARD__AMERICAN;
	 assign_channel(1, channel_assignment_data);
void configure_global_parameters() {
	// -- Set global parameters
	write_single_byte(0xF0, TEMP_UNIT__C |
	REJECTION__50_60_HZ);
	// -- Set any extra delay between conversions (in this case, 0*100us)
	write_single_byte(0xFF, 0);
// -------------- Run the LTC2983 -------------------------------------
int main(void) {
	setup();
	float temperature_result;
	int channels_to_measure[] = {1};
	int num_measured_channels = sizeof(channels_to_measure)/sizeof(channels_to_measure[0]);
	for (int i = 0; i < num_measured_channels; i++) {
		channel_number = channels_to_measure[i];
		convert_channel(channel_number);
		read_voltage_or_resistance_results((channel_number)); // removed int
		read_temperature_results((channel_number));           // removed int
// header file.h
#ifndef LTC2983_SUPPORT_FUNCTIONS_H_
#define LTC2983_SUPPORT_FUNCTIONS_H_
void initialize_serial();
void initialize_spi();
void write_custom_table(struct table_coeffs coefficients[64], long start_address, long table_length);
void write_custom_steinhart_hart(long steinhart_hart_coeffs[6], long start_address);
void write_single_byte(long start_address, int single_byte);
void initialize_memory_write(long start_address);
void write_coefficient(long coeff, int bytes_in_coeff);
void finish_memory_write();
void initialize_memory_read(long start_address);
void finish_memory_read();
void convert_channel(byte channel_number);
boolean conversion_done();
float read_temperature_results(int channel_number);
float read_direct_adc_results(int channel_number);
void get_raw_results(long base_address, int channel_number, unsigned char results[4]);
float convert_to_signed_float(unsigned char results[4]);
float get_temperature(float x);
float get_direct_adc_reading(float x);
void print_temperature_result(int channel_number, float temperature_result);
void print_direct_adc_reading(int channel_number, float direct_adc_reading);
void print_fault_data(unsigned char fault_byte);
bool is_number_in_array(int number, int *array, int array_length);
// -------------- Some raw data result...
float read_voltage_or_resistance_results(int channel_number);
float convert_vr_to_signed_float(unsigned char results[4]);
float get_voltage_or_resistance(float x);
void print_voltage_or_resistance_result(int channel_number, float voltage_or_resistance_result);
#endif
Undefined ref. means you haven't added the C file(s) that provide those functions to the list of C files in the project. It's not enough to simply #include the header files (though you must do that too).
main.c, all headers.h and .cpp are in the libraries folder.
The .cpp file works with the header.  In a dumb way does Amtel Studio 6.2 not support .cpp files, or is this file in the wrong place.
Thanks for your help.
I  already told you what's wrong and how to fix it. Which bit of my answer didn't you understand?
hint: just putting the files in the same directory does NOT add them to the list of files to be compiled and linked.
The code looks like a mix of Arduino and common C/C++.
The Arduino IDE scans all the source, finds/includes the necessary libraries in source form, builds the function prototoypes, etc. It's weird.
I think your build config lacks the inclusion of the .a libraries for pre-compiled functions you are trying to use.  Not sure where these would come from, sans Arduino's IDE.
Hi Stevech,
Well spotted on the Arduino part.  The sensor is connected to an Arduino developement board.  But now I want to put it on my standard ATmega328P chip.  So I am struggling but slow moving it accross now.
You can burn the arduino code onto a mega328. The only 'magic' the arduino uses is the boot loader - and that is not needed if you have a isp programmer.
