Terrarium heating
4 posts / 0 new
Hello All,
I am also fairly new to everything called microcontroller but I think it is the
best sollution for my heating problem in my terrarium.
I would like to know if it is possible to drive heat and moisture sensors on the
AVR controllers.
Also I would like to know wich programmer I must have for programming of all
different standard AVR. I was thinking about the STK500.
greetings to all,
John
admin's test signature
The STK500 works with all AVRs except the ATmegaxxx. Keep that in mind.
Dieter,
The STK500 supports all ATmega parts also, with the current exception of ATmega103(L) due to its package size.
Best regards,
Morten, AVR tech. support, Atmel FAE
for temperature sensing I normally just use a 2n2222 with emitter and base wired together. The junction drop created is relatively inverse linearly related to temperature, and the a/d in the avrs can get decent resolution of this to at least half a degree.
The humidity sensors I have seen in the past are basically variable resistors, stick a fixed resistor with it to make a voltage divider and you can measure that voltage with the a/d as well.
