I'm trying to connect a DHT-11 with an ATMega8. I'm not much proficient in this field, and just a passion-driven beginner. I can use the ADC well now, but I'm still learning digital libraries and registries.
I'm searching for codes and libraries to use with DHT-11. The most promising I found is the David Gioroni's DHT-11 library. But unfortunately, in his code, the output of the DHT-11 is sent to UART. I need to display them on a 16x2 LCD.
I tried a lot for 3 days, but couldn't get it working.
Can you please help and edit the code?
This is the main code.
#include <stdio.h> #include <stdlib.h> #include <avr/io.h> #include <avr/interrupt.h> #include <util/delay.h> #include "dht/dht.h" #define UART_BAUD_RATE 2400 #include "uart/uart.h" int main(void) { char printbuff[100]; //init uart uart_init( UART_BAUD_SELECT(UART_BAUD_RATE,F_CPU) ); //init interrupt sei(); #if DHT_FLOAT == 0 int8_t temperature = 0; int8_t humidity = 0; #elif DHT_FLOAT == 1 float temperature = 0; float humidity = 0; #endif for (;;) { if(dht_gettemperaturehumidity(&temperature, &humidity) != -1) { #if DHT_FLOAT == 0 itoa(temperature, printbuff, 10); #elif DHT_FLOAT == 1 dtostrf(temperature, 3, 3, printbuff); #endif uart_puts("temperature: "); uart_puts(printbuff); uart_puts("C");uart_puts("\r\n"); #if DHT_FLOAT == 0 itoa(humidity, printbuff, 10); #elif DHT_FLOAT == 1 dtostrf(humidity, 3, 3, printbuff); #endif uart_puts("humidity: "); uart_puts(printbuff); uart_puts("%RH");uart_puts("\r\n"); } else { uart_puts("error"); uart_puts("\r\n"); } uart_puts("\r\n"); _delay_ms(1500); } return 0; }
Thanks a bunch, in advance!
