Xmega virtual ports---definitely use them for manipulating single bits!
12 posts / 0 new
I was surprised (or simply blissfully ignoring) how much more efficient the Xmega virtual ports are when dealing with single bits...much more code and speed efficient:
This is due to allowing the use of sbi & cbi & in & out
#define PORTA_Virt  VPORT0 // just a naming substitution for clarity
#define PORTB_Virt  VPORT1
int main(void){
//NOTE the port directions (.DIR) have not been configured, but need to be for actual usage
 PORTA_Virt.OUT |=PIN4_bm; // set a specific pin using virtual port
 PORTA.OUTSET=PIN4_bm;  // set a pin using std port (same as PORTA_Virt, if already configured as noted below)
        // this code will compile 4x longer/slower  (3x If Z already set)!!
 PORTB_Virt.OUT &= ~PIN4_bm; // reset a pin using virtual port
 PORTB.OUTCLR=PIN4_bm;  // reset a pin using std port
 // the following configurations are needed, VPorts are UNASSIGNED  upon reset....these must be placed PRIOR to making the above virtual pin changes
 PORTCFG.VPCTRLA=PORTCFG_VP0MAP_PORTA_gc|PORTCFG_VP1MAP_PORTB_gc; // assign the virtual ports A==>VP0, B==>VP1
 PORTCFG.VPCTRLB=PORTCFG_VP2MAP_PORTC_gc|PORTCFG_VP3MAP_PORTD_gc; // assign the virtual ports C==>VP2, D==>VP3
The compiled code shows a large improvement with the virtual ports:
 PORTA_Virt.OUT |=PIN4_bm; // set a specific pin using virtual port.....NICE AND QUICK
 184: 8c 9a        sbi 0x11, 4 ; 17
 186: 80 e1        ldi r24, 0x10 ; 16
 188: e0 e0        ldi r30, 0x00 ; 0
 18a: f6 e0        ldi r31, 0x06 ; 6
 18c: 85 83        std Z+5, r24 ; 0x05   .......SING A SAD DOG SONG
 18e: ac 98        cbi 0x15, 4 ; 21
 190: e0 e2        ldi r30, 0x20 ; 32
 192: f6 e0        ldi r31, 0x06 ; 6
 194: 86 83        std Z+6, r24 ; 0x06
It would be nice to have some sort of macro to allow  "virtual compatibility" (only for a single pin) with a statement such as:
PORTB_Virt.OUTCLR=PIN4_bm;    //same as PORTB_Virt.OUT &= ~PIN4_bm;
That shouldn't be impossible, I'll scratch my head on it
Of course, the standard Xmega OUTCLEAR, allows multiple bits to be simultaneously cleared, at about the same rate/length as the mega/tiny read (IN), modify (AND/OR), write (OUT) dance
But why bother if "PORTB_Virt.OUT &= ~PIN4_bm;" achieves the same thing? Why not just type that?!? After all it should become a single CBI.
Some people don't like typing I guess.
I'm wondering if the compiler would be clever enough to reduce compile time constants down to zero RAM and a single instruction. Like say you had something like
typedef struct = {
    REAL_PORT *real_port,
    VIRT_PORT *virt_port,
    uint8_t mask
    bool virtual;
} PORT_PIN_t;
const PORT_PIN_t led_pin = {NULL, &VPORT0, (1<<5), true);
static void set_pin_high(PORT_PIN_t *pin)
    if (!virtual)
        pin->real_port->OUTSET = pin->mask;
        pin->virt_port->OUT |= pin->mask;
You could probably create a load of macros to generate everything you wanted and have a nice easy "Arduino" style interface if you wanted to.
But yes, I agree with clawson, just type faster :-)
Interesting.
It's also worth noting that virtual ports can be slower in some circumstances. cbi/sbi can only act on one bit, where as the OUTSET/OUTCLR registers can operate on multiple bits.
Yeah but the compiler KNOWS that. If you write code to affect 2+ bits on any AVR that has IO in SBI/CBI range the compiler will switch to IN/<and/or>/OUT - it's still faster than it doing LD/<and/or>/ST.
On an Xmega you should always map your four most heavily used GPIO to the VPorts.
In a thread previously (several years ago) I opined the wasted opportunity in Xmega - there's some IO space that could have been used for more VPorts that is just wasted :-(
Hay, the compiler did a good job :-) With optimization at -O1 and a real port:
static inline void pin_high(const PORT_PIN_t *pin)
	if (!pin->is_virtual)
 22c:	81 e0       	ldi	r24, 0x01	; 1
 22e:	e0 e0       	ldi	r30, 0x00	; 0
 230:	f6 e0       	ldi	r31, 0x06	; 6
 232:	85 83       	std	Z+5, r24	; 0x05
And with a virtual port:
		pin->virtual_port->OUT |= pin->mask;
 22c:	88 9a       	sbi	0x11, 0	; 17
Yes, but with IN/OUT you have to do a read-modify-write, so three or four instructions (there is no immediate EOR for toggling). It's not atomic either.
It would be nice, certainly, as would virtual SET/CLR/TGL registers. I imagine the limit is in silicon though, with MUXes being somewhat expensive.
But this is nothing to do with Xmega/Vports. It's always been like this...
$ cat avr.c
int main(void) {
	PORTB |= (1 << 3);
	PORTB &= ~(1 << 5);
	PORTB |= 0xAA;
	PORTB &= ~0xAA;
$ avr-gcc -mmcu=atmega16 -Os -g avr.c -o avr.elf
$ avr-objdump -S avr.elf
   [SNIP!]
0000006c <main>:
int main(void) {
	PORTB |= (1 << 3);
  6c:	c3 9a       	sbi	0x18, 3	; 24
	PORTB &= ~(1 << 5);
  6e:	c5 98       	cbi	0x18, 5	; 24
	PORTB |= 0xAA;
  70:	88 b3       	in	r24, 0x18	; 24
  72:	8a 6a       	ori	r24, 0xAA	; 170
  74:	88 bb       	out	0x18, r24	; 24
	PORTB &= ~0xAA;
  76:	88 b3       	in	r24, 0x18	; 24
  78:	8a 7a       	andi	r24, 0x55	; 170
  7a:	88 bb       	out	0x18, r24	; 24
  7c:	08 95       	ret
0000007e <_exit>:
  7e:	f8 94       	cli
00000080 <__stop_program>:
  80:	ff cf       	rjmp	.-2      	; 0x80 <__stop_program>
That's mega16 code.
The point of this thread surely is: you can get GPIO performance on an Xmega as good as you can get on tiny/mega *IF* you map your 4 most used ports to the VPorts.
Sure, my point is that with the XMEGA ports that have OUTSET, OUTCLR and OUTTGL which occasionally can be faster if you need atomic updates, or if you want to generate a little square wave or something like that. It's a rare corner case but still...
What I don't get is why the compiler bother going through Z in the first place (when it is used as a constant that is).
This would do the same, in less cycles and in less codespace:
ldi  r24, 0x01
sts  0x0605, r24
I never bothered with virtual ports. I find outclr/outset of greater value to me, avoiding the problems with non-atomic read-modify-writes.
What I like about XMega and bit-addressing, is the gpio registers at address 0-15. They are great for boolean flags. Setting and testing bits there is fast and atomic.
It uses Z if the same (or other close) destination is accessed several times in the same function. It then saves code. Observe:
$ cat avr.c
int main(void) {
	UDR0 = 0x55;
$ avr-gcc -mmcu=atmega168 -Os -g avr.c -o avr.elf
$ avr-objdump -S avr.elf | tail -n 16
00000080 <main>:
int main(void) {
	UDR0 = 0x55;
  80:	85 e5       	ldi	r24, 0x55	; 85
  82:	80 93 c6 00 	sts	0x00C6, r24
  86:	08 95       	ret
00000088 <_exit>:
  88:	f8 94       	cli
0000008a <__stop_program>:
  8a:	ff cf       	rjmp	.-2      	; 0x8a <__stop_program>
but:
$ cat avr.c
int main(void) {
	UDR0 = 0x55;
	UDR0 = 0xAA;
	UDR0 = 0xFF;
	UDR0 = 0x00;
$ avr-objdump -S avr.elf | tail -n 22
int main(void) {
	UDR0 = 0x55;
  80:	e6 ec       	ldi	r30, 0xC6	; 198
  82:	f0 e0       	ldi	r31, 0x00	; 0
  84:	85 e5       	ldi	r24, 0x55	; 85
  86:	80 83       	st	Z, r24
	UDR0 = 0xAA;
  88:	8a ea       	ldi	r24, 0xAA	; 170
  8a:	80 83       	st	Z, r24
	UDR0 = 0xFF;
  8c:	8f ef       	ldi	r24, 0xFF	; 255
  8e:	80 83       	st	Z, r24
	UDR0 = 0x00;
  90:	10 82       	st	Z, r1
  92:	08 95       	ret
00000094 <_exit>:
  94:	f8 94       	cli
00000096 <__stop_program>:
  96:	ff cf       	rjmp	.-2      	; 0x96 <__stop_program>
