Xmega256 communication via ENC28J60
5 posts / 0 new
I am looking for a tutorial or some good information on how to communicate between the Xmega256 SPI and ENC28J60.
Any information would be helpful.
Other thread removed.
JIm
The ENC28J60 neither knows nor cares what microcontroller you use - so "how to communicate" over SPI with it is entirely independent of the microcontroller.
So is your question really, "how to use the SPI peripheral of the Xmega256?"
ejleiss wrote:
ENC28J60 is (ancient and) the hard way to go.
Better to use a board from Wiznet. Full off-load of TCP/IP/ICMP/ARP and has sockets and socket buffers onboard.
The newest (and thus not the lowest cost) is
WIZ550io
The wiz820io is middle-aged.
The wiz812MJ is older. but fine.
