Atmel Studio using Adrunio Sketch compiler errors
3 posts / 0 new
Hello folks,
Visual Studio worked perfectly 6 months ago ... Arduino sketches compiled and downloaded ... no surprises ... everything worked as advertised.
A few days ago I was going to modify a project ... did the modifications and nothing but problems - can't find main() ERROR once again - no changes to this software or the IDE for Arduino.
Okay - (a few choice thoughts) - uninstalled Visual Studio b/c this worked last time to fix it.  Reinstalled it and everything is GOOD.  No 'can't find main()' errors.
I aquired a newer version of the Arduino IDE.  Installed it and I have many 'redefinition' errors on projects that were compiling just fine 6 months ago.  The same projects compile correctly under Arduino ERW 1.0.5.  Nope, not the coding ... I copied the identical text into a new Visual Studio sketch and it compiled as it should.  Everything worked as expected.
The whole thing is I don't want to have to recreate each and every sketch (cut/paste/save) I have ... not very many but I'd imagine there are some folks with hundreds if not thousands ... that would really be a pain if one has to go back and fix each and every project.
Anyone know if there is/was a change in upgrading that causes this?  I did an upgrade (now regretting it) ... Studio works well for my projects and familiar with Visual programming (basic, C, etc).
I came up with possibly an old incremental build file but tried for a clean build without success.  I am not as familiar with the newer Visual Studio stuff as I'd like to be.  I don't mind finding all the old build files and killing them off .. no harm there.
Thanks for your help!
Eddie
Such as?
But really I'd be talking to Visual Micro about this - it's their extension that does the "Arduino trick" and any problem is likely in that domain.
MMMM ... after careful examination of the errors, apparently the IDE is processing all the files in the folder - this is bad b/c i put backups (copied file to same directory).
However in the project window it only lists the primary sketch.  Renaming the file to something else other than *.ino fixed this problem (as with most, I changed it to *.bak)
Hmpppffff ... well something changed with the upgrade and now I found it.
Thanks for your reply.  I didn't see this coming but now it's good.
Eddie
