FreeLance Needed - ATTiny 24A, 3 logic and 1 analog I/O..
14 posts / 0 new
Need a program in C, should be simple for person who knows what he is doing ...
a)  1 analog  input to read voltage
b)  1 logic input for selecting mode
c)  1 logic output  for thermistor network
d)  1 logic output (sound)
Reset on power OFF/ON with beep when back to ON...
Device is powered from single button cell (3V), main requirement is current draw around 1uA (Power down Mode, 80-95% of the time, wake up on change @ a) ) and low battery...
Low battery indication (audio)...
Of course, this will be a contract...
Please elaborate on...
A thermistor is a sensor for measuring temperature whose resistance changes with temperature according to particular constants. It is more normal to connect a thermistor to an input rather than your stated output.
Is this a school assignment? More information is needed to suggest a solution.
Ross McKenzie, Melbourne Australia
How do you propose to wake up on a change in analog voltage?  An AVR alone cannot do this.
1 uA will be exceedingly hard to do with only an AVR.  The ATtiny24A lacks the ability to clock a timer with a watch crystal.  There are AVR which can do so (48/88/168/328 for example), and can get down to 0.75 uA in sleep mode (in theory).  The 24A would need another wakeup source.  The best is likely to be the WDT at 4 uA.
But that doesn't include draw while awake.  You will need to wake up to perform take an ADC sample, and that will take orders of magnitude more power than sleeping, even if you wake only infrequently.
You'll need to give more details about what you're trying to accomplish, not how you want to accomplish it.
Consultants (as I am) start with What, now How!
Example: I need the device to do A, B, C, D every y amount of time. And run on a battery for X days/hours. And fit in an enclosure of this size. And tolerate environment of xxx.
and so on.
Functional requirements.
Apart from the technical details,
Where are you located?
What is your budget?
How do you propose to pay?
I am attaching a file with chart diagram and  better explanation of the functions and I/O... My thought was, that if thermistor is powered by output, I just eliminate current going continuously through the device and additional resistor (divider)... That alone is 19uA on 3VDC power... If this is done in intervals 1sec. every 15 sec., the consumption will go down significantly...
I am in US, (SouthEast)...
Yes, there is a modest budget... :o)
PayPal perhaps?
         Thanks for all replies...
Got any programmers working with you yet? 'SouthEast' might be near me, compared to the other 3 quadrants.
Yes he does
I am waiting on parts from Digikey to build a prototype.  Code is done.
FooFoo. I got all excited and started looking at the flowchart, and the very first problem was a tiny24 didnt have a porta. Did you point that out Jim? Did he post a revised spec?
...and the very first problem was a tiny24 didnt have a porta. Did you point that out Jim?
IT dosen't?
JIm
EDIT:
Doh! I was looking at a 25. "Never Mind"
OK jgmdesign
you too have make the code.
I have send him ,code and new schematic some can use less current than he was thinking.
I have tested on my prototype (and work) and he answer at my code do not work with him....
OK if you continuous with him, good luck.
Thierry
Thierry Pottier
Thierry,
PM sent.  Was not aware of a few things.
JIm
It seems that The OP may have double booked two Freaks.
In all fairness to Thierry, I am going to have a talk with the client and make sure he is compensated for his work.
I am also locking this thread as there seems to be nothing more that needs to be said.
Topic locked
