hi
in astable mode of 555 i have square wave of 50% duty cycle.
i WANT TO use it for measure L of inductor but when i place my inductor ,square wave is gone.
why this is happening?
problem with 555
Where, exactly, do you place your inductor?
And how do you determine that the square wave is "gone"?
Post a schematic - here's the instructions: https://www.avrfreaks.net/wiki/em...
Whats the frequency response of a serial L/C circuit?
frequency does not change. its 100 KHz and with LC serie it does'nt change just square wave is falling apart
What does that mean??
Why did you not follow the instructions for inserting the schematic?
IT IS ASTABLE MODE 555 CIRCUT THAT IS GIVING SQUARE WAVE.
ITS MIDDLE ONE
What did you expect? Do you understand how an inductor works?
The inductor builds field strength as current flows through it. The series cap means that when the 555 output goes high, the current starts high and then falls off as the cap charges up. The current through the inductor stops, the field collapses, which induces a sharp spike of current in the opposite direction. When the 555 toggles the output low, the cap discharges, again starting with a high current, building field strength in the inductor. Once the cap is discharged, current stops, field collapses, sharp spike in opposite direction. Rinse and repeat.
Sure looks like your second image...
There are lots of easy ways to measure the value of an inductor. This is not one of them. Did you follow the link I posted above?
Maybe have a look at some of these too:
SEE the attachment . when inductor field collapes its goes throuth diods and it is working now
thanks alot
if any suggestion u have i will be greatfull to know
Which country are you in? I just looked at "Inductance meter" on my local ebay and the cheapest meter is about £5. It's not surely worth trying to make up circuits when you can buy the ready made thing for virtually the same cost of the components you might need and you'll end up with something that's guaranteed to work and work reliably. If you build your own how do you actually know it's working right if you have nothing to check against?
(rhetorical: is it heresy to suggest such a move?!?)
Navid,
Please stop using capital words (because it's pointless and we think you are shouting at us. then it's kinda rude) and don't use some childish words like "plz" or "wanna" and use capital "I" when you refer yourself and spend more times to write your posts. sounds like your grammer isn't so good. do you know why these guys here ask you "why don't you google it"?
because they think you can understand English but you don't want to search on internet. in other word, they think you are lazy. if you can understand English then why don't you post all things you want to do and what's your problem.
Why don't you follow the link that Joey has mentioned?
because blogspot is blocked in Iran then I converted that link to PDF. there you go:
http://vmaniac.com/files/apexys_toan_blogspot_ca_2011_02_ne555_based_inductivty_meter.pdf
Iran
actualy i WANT TO build one rlc meter.not with 555.
its like a practice to me.
inductance meter that cost only 5 euro is not reliable . i have one but its not accurate as i want it to be.
Do you HONESTLY think something you cobble together with a 555 is going to be MORE reliable?!
Get a handheld meter that reads L and C in addition to volts and ohms?
Elmcie is one uC inductor meter.
AN #172 Inductance Meter is another one.
Both might give you some good ideas about how others have done this.
well i have good oscop . and 555 give me good square wave . then y not?
Just did a Google "how to measure inductance with a scope". There's a bit of reading.
You probably want a sine wave source, not a square wave.
I want to measure L .for that I want di/dt.in squire wave I can do that .because inductor will smooth di little bit.
it's what's in my mind.
please if I'm wrong, tell me
thanks for answering
And if you are going to use a square wave then what you have is not a square wave. The tops are nasty.
This looks like you have a second signal at a very close frequency running through the trace - what is the cause of that?
David
I don't know.should it change?y should it change?
My guess is that you power don't handle the extra power when the diodes open , very well
How good are the PSU, some good caps over GND and VCC near the 555 would probably help.
I thought it might be mains frequency related but the frequency doesn't tie in, unless the scope is out of cal.
David
thanks I should consider that.I'll add cap.thanks
Why is it happening - because you made it! What do you expect to happen? You created the circuit - surely you have some expectation of what you might want to achieve?
Why don't you use the simulator to show you current and voltage across the inductor and the capacitor? This might give you a better idea of what is happening. You have the tools at your fingertips - use them.
which simulator u recommend?
avr freaks forum is not working for me.nobody answer and just complaining
WELL I WANT TO KNOW WHY THIS CIRCUT IS WORKING LIKE THIS?
IF I CREAT A SQUARE WAVE WITH LTSPICE THE SQUARE WAVE WILL NOT FALL APART LIKE THIS?
I JUST WANT TO KNOW WHY WHEN I USE 555 AND HAVE A SERIE OF LC ON OUTPUT IT BECAME LIKE THIS
U DONT GET IT.DO U?
NOW JUST COMPLAIN
You should remember that this forum is not here just to solve your problems for you. You will have to think about the problem and do some research. Also shouting (UPPERCASE TEXT) will not win you any friends.
David
David
sorry
i get it now its because LTspice voltaj internal resistance of voltaj source of mine was zero . in 555 i should have buffer for output
Over your dummy spit? Try using stack exchange and see what reception you get if you don't like the free service here.
What simulator do I recommend? How would I know? I was brought up using pen and paper, simulators are novel to me. You mentioned LTSpice - if that works for you, use it. You've been using a simulator judging by your pictures. You only look at the voltage, the other part of the picture is in the current so set your simulator to show the current waveform as well. Just don't ask me how to do it - I have NFI.
*unnecessary words removed. Moderator*
anyway thankyou all guys . i learned somthing in every post that u post
I think you're missing the point. I'm trying to give you the tools to answer your own questions. One day you might realise this.
Anyway, what you wrote makes no sense. I have no idea of what you're try to say.
I think you're missing the point. I'm trying to give you the tools to answer your own questions. One day you might realize this.
no need for that one day because right now i know that i asked a dummy question and by a little googling will be find out.
my body here say that mr kartman is right and i should take lesson from him to not ask a dummy question again. lesson taken
Did you even bother to look at the TWO AVR inductance meters I provided links to in Post #7 above?
Theirs works.
Yours doesn't.
One might want to spent a moment studying their approach, and comparing it to yours.
If you want to use an alternative technique, (there is more than one way to solve most problems), then you need to expect to spent a lot of time designing the circuit, and debugging it.
Analog design, especially with LC circuits, isn't trivial.
Theirs works.
Yours doesn't.
yes
thankyou
Navid
I warned you that such asking isn't wisely.
personally I think you got the best consultations here. nobody want to insult you or solve your homework. you cannot ask your pre-answered questions although all guys tried to suggest a better circuit or a source to introduce the fundamentals of L meters. you didn't even bother yourself to read them, did you?
and about Kartman and other friends here I have to say that he is like a father for me. I like all of the freaks.
also you shouldn't be disappointed for your problems. as Kartman said check out your circuit in simulation and tell them what's the problem. you think the problem is that the circuit doesn't make the output you expected but that's not the problem. that's your goal. the problem is what's going on there that you do not get the output you expected!? then simulate it and tell our friends what's going there.
Good luck
Navid
personally I think you got the best consultations here. nobody want to insult you or solve your homework. you cannot ask your pre-answered questions although all guys tried to suggest a better circuit or a source to introduce the fundamentals of L meters. you didn't even bother yourself to read them, did you?and about Kartman and other friends here I have to say that he is like a father for me. I like all of the freaks.
Good luck
yes you are right.and im sorry all guys.
i get that and solve my problem.
thanks
I haven't used a 555 since I started using avrs. But then, you can use a 555 in a 9v system without a regulator...
EEK! I lied! I made a coupler trigger for Larry 'cause he wanted a circuit he could build and "not any of your d*^m surface mount crap."
It's just easier to tell an avr how long I want the pulse to be than to find R and C of the right values. Especially since you can't go down to Radio Shack and get them any more.
in next measurment i will use microcontroller
