which SPI mode is this
3 posts / 0 new
1. I have a slave device running on SPI which needs to communicate with MCU. In slave datasheet attached SPI diagram is given.
2. I need to set MCU SPI mode.
3. Which SPI mode is this. I think its SPI mode 1 because transmitter data i.e which is master have valid data on falling edge of clk.
Why don't you say what the mystery "slave device" is - and give a link to its datasheet, so that we can see the full information?
Which MCU are you using? What does its datasheet say about its available SPI Modes?
The combinations of polarity and phases are often referred to as modes which are commonly numbered according to the following convention, with CPOL as the high order bit and CPHA as the low order bit
http://en.wikipedia.org/wiki/Ser...
Note the vague terms "often" and "commonly": because there is no formal definition of SPI, you really need to check the datasheet of your specific MCU to be sure of the terminology that it uses.
frown
Place your picture in the post - rather than as an attachment - so that we can actually see it:
Instructions for embedding images: https://www.avrfreaks.net/wiki/em...
I'd guess mode 0.
