First attempt on Attiny2313 with Raspberry Pi, LED turned on, but doesn't blink
5 posts / 0 new
Hi, newbie here
i'm trying to program attiny2313 using raspberry pi via SPI connection. Here i'm just trying to blink an LED. The HEX file from my source code is uploaded successfully to the MCU, The LED is turned on but the problem is it's not blinking. I need help finding out the main cause, i've tried changing the F_CPU, but that doesn't work, please help.
here's my source code :
#define F_CPU 1000000UL
#include <util/delay.h>
int main(void) {
    DDRB = 0xff;
    PORTB = 0x00;
    for(;;) {
        PORTB ^= 0xff;
        _delay_ms(1000);
    return 0;
and this is the makefile :
all:
    avr-gcc -Os -mmcu=attiny2313 -Wall -c main.c -o main.o
    avr-objcopy -O ihex main.o main.hex
upload:
    gpio -g mode 22 out
    gpio -g write 22 0
    avrdude -p t2313 -P /dev/spidev0.0 -c linuxspi -U flash:w:main.hex
    gpio -g write 22 1
clean:
    rm -rfv main.o
    rm -rfv main.hex
Formatted code for clarity - JGM
The program should end with infinite loop put while(1); at the end.
Your source code is just fine.   The for(;;) ensures that the loop is repeated forever.
It is wise to put a catch-all while(1); at the end of a main() but not strictly necessary.    The startup code disables interrupts and provides the catch-all anyway.
The biggest problem is your avr-gcc command.
Just look at the real avr-gcc commands from a proven IDE or Makefile.
You need to produce an ELF file.
The objcopy is wrong. You either want -j's or -R's
Thanks a lot for the advice guys, the LED is finally blinking now yes
here are the changes i've made in the makefile :
all:
    avr-gcc -g -Os -mmcu=attiny2313 -Wall -c main.c
    avr-gcc -g -mmcu=attiny2313 -o main.elf main.o
    avr-objcopy -j .text -j .data -O ihex main.elf main.hex
upload:
    gpio -g mode 22 out
    gpio -g write 22 0
    gpio -g write 22 1
clean:
    rm -rfv main.o
    rm -rfv main.hex
    rm -rfv main.elf
