XMEGA ADC, How to show?
2 posts / 0 new
XMEGA ADC
using CVAVR produce ADC, but I do not know how to use the seven-segment display show??Cry
This PCB is to produce their own.
I am a novice .....SmileSmile
I do not know how to change .....
// ADCA channel 0 interrupt service routine
// Interrupt Mode: End Conversion
Interrupt [ADCA_CH0_vect] invalid adca_ch0_isr ( void )
{ unsigned int data;
// Read the AD conversion result
signed int data; // Read the AD conversion result
((unsigned char *) &data)[0]=ADCA.CH0.RESL;
((unsigned char *) &data)[1]=ADCA.CH0.RESH; // ADC offset compensation
data-=adca_offset;
// Your code here processing data stored in the "data" ADC results
Void main (void)
While (1) {}
Well for one thing you need "data" to be a global outside the interrupt code as you will want to do the display stuff outside the interrupt (which should be kept as short as possible). Also:
Seems a very complicated way to achieve the same as:
data = ADCA.CH0.RESL;
data |= (ADCA.CH0.RESH << 8);
