I have a requirement to run a mega32 chip at 3 volts in an application where it is currently clocked at 14.7MHz. The non-L suffix mega32 is specified to run with Vcc of 4.5 to 5.5 volts up to 16MHz. The L-suffix part is specified to operate from 2.7 to 5.5 volts but only up to 8MHz.
Of course, I can modify the code to run at 7.37MHz in order to avoid overclocking the L-suffix part. However, I'd like to hear from people that have experience with operating non-L parts at 3 volts or overclocking the L parts running at 3 volts in production volumes.
