ATMEL Studio 6.2, how to modify serial target from STDIO.h to specfic UART port, USART0 or USART1
6 posts / 0 new
I could not find material in Atmel that allow retarget (as in LPC, TI devices) serial message stream to specfic port using printf("") function.
I surprised the topic has very little discussed.
I use Arduino Due (SAM 3X) board and using ASF to configure the UART, USART0 and USART1.
No idea about the SAM chips but with Mega/Xmega/Tiny chips you use fprintf to send to different channels.
#include <stdio.h>
#include "com_ports_test_init.h"
#define PI 3.141593
int	main(void)
	com_ports_test_init();
	printf("Printing on com 0\r\n");				// Using stdout	956 bytes
	fprintf(com0, "Printing on com 0 with fprintf\r\n");		// 1086 bytes
	fprintf(com1, "Printing on com 1 with fprintf %d\r\n",12345);	// 2576 bytes
	fprintf(com2, "Printing on com 2 with fprintf %f\r\n",1.23456);	// 2664 bytes
	fprintf(com3, "Printing on com 3 with fprintf %f\r\n",PI);	// 2750 bytes
	for(;;);
You need of course to set up the various com streams, but it may just be all different with SAMs.
Using ASF with the Xmega, there is a module called stdio_serial or something like that that allows you to specify the USART in a .h file.  Since the goal of the ASF is to abstract the specific hardware you are working with, I assume this is available for the SAM devices as well.  If not using ASF with the Xmega, there is a method for doing this in avr_libc.  I don't know if there is a sam_libc somewhere, but it would be searching for.  You are surely not the first person to try to do this.
Greg Muth
Portland, OR, US
Make Xmega Great Again!
If you're using newlib, check out:
http://forum.43oh.com/topic/8308...
tl/dr: use fopencookie() with user-provided read/write functions.
(Does ASF/AS6.x end up using newlib for ARM builds?)
ssize_t myWrite(void *cookie, const char *buf, size_t n)
  return Serial.write((uint8_t*)buf, n);
cookie_io_functions_t myVectors = { 0, myWrite, 0, 0 };
void setup() {
  Serial.begin(115200);
  stdout = fopencookie((void *)0, "w", myVectors);
  setlinebuf(stdout);
  printf( "This is an fprintf demo\n");
    I'd love to get the serial terminal to work in the Atmel Studio 6.2 debug simulator, on my ATmega328P projects.  I have that "Terminal for Atmel Studio" extension.
    But I don't see any file called  "com_ports_test_init.h" in my Atmel Studio installation.  Can you elaborate on what you are showing us here ?
    - Thanks
That's because it's my file not studio smiley
