Release Name: 2.0.6.1
Notes:
Programmers Notepad 2 is a fast, slimline, but powerful text
editor for Windows (see http://www.pnotepad.org/). This is a
maintenance release for 2.0.6-ella fixing a few annoying user
interface bugs and some other minor issues.
Download here: http://prdownloads.sourceforge.n...
Changes:
Build: 2.0.6.1, Version Label: ella
Bug Fixes:
1) Tab bar movement with tabs on the bottom (SF #1329197, #1337576)
2) Crashes with project reorganisation (SF #1351978)
3) Unexpected error running tools (SF #1333875)
4) Fix for inserting text clips with a text selection
5) Command-line paramters not working (SF Bug #1334272)
6) Smart Start error when loading files (SF Bug #1353959)
7) combobox does not expand (SF Bug #1362181)
8) Options dialog UI bugs (SF Bug #1361814)
Release Name: 2.0.6-ella
Notes:
This marks the first "stable" release of PN2 - the open source text
editor (http://pnotepad.org/) for Windows. Lots of good features in
this release, and lots of bug fixes too. Many of the features allow
people to build around PN2 so we're looking forward to seeing
some good uses of the new projects features.
This build also sees built-in support for new languages (including
Ruby and Assembler), brace matching and configurable file type to
scheme mappings.
In addition, with this version out the door work starts on even more
exciting features for PN2 - keep an eye on the blog at
http://untidy.net/blog/ for news or join the mailing list
(http://pnotepad.org/lists.html) to get involved and test early builds!
Changes:
What's new?
1) Project Properties
2) Editable Magic Folder Properties
3) Ctrl+H for Replace.
4) Right-Click on a file to add to a project.
5) Selected text insertion into find dialog is more selective (no pun intended).
6) Project changed indicator (appends * to name).
7) Project tools.
8) Tab usage option per scheme (SF RFE #1050938).
9) Stack Based Ctrl-Tab Ordering (SF RFE #995790).
10) Browse for folder in find in files dialog.
11) Support for vbc compiler output (SF Bug #1168477).
12) Docbook Scheme
13) Scintilla version 1.6.6
14) CSS-2 Support in CSS lexer
15) Projects remember folder expansion state.
16) Added Ctrl-W to close the current file (as well as Ctrl-F4) (SF RFE #1169428).
17) New Project dialog.
18) Save project from context menu.
19) Refresh magic folder from context menu.
20) Ctrl+[ jumps to matching or nearest brace.
21) Ruby scheme
22) Better behaviour with files opened using relative paths.
23) Wrap text clips around selected text (SF RFE #1199676).
24) Escape key closes find results if no output windows are open.
25) Optionally save workspace between runs ("Remember open files and projects between sessions" in General options).
26) Open to save workspace files from File menu, opening a .pnws file opens the saved workspace.
27) SmartStart applied to opened files.
28) New Incremental FindBar (Press Ctrl+/ and start typing, escape to cancel).
29) Customisable scheme mappings (choose schemes for file types - Options|Files).
30) Find Previous - Shift+F3
31) Support for Java properties files (SF RFE #1267017).
32) Find in Files can ignore hidden files.
33) Remember Selected Text Clips Set (SF RFE #1279158).
34) Press Enter to insert a text clip (SF RFE #1259865).
35) Show textclips in tool tip text (SF RFE #1116510).
36) Add Assembly Scheme (SF RFE #1290453).
37) No more default comic sans for comments in web schemes!
38) Support Ctrl+Shift+[X|V] for VNC cut-paste with caps lock support, Ctrl+Shift+C already taken for clipboard swap.
Bug Fixes:
1) Find in Files gets selected text.
2) Find in selection fixed.
3) Find Next and Replace One no longer supported in "in selection" mode.
4) Find Next replaces selection in find text box when text not found.
5) Switching tabs causes "re-maximization" (SF Bug #1169434).
6) Launch Search Dialog With No Document (SF Bug #1168100).
7) "Allow backslash expressions" does not work in search.
8) Crash on Running Find in Files With Operation in Progress (SF Bug #1168101).
9) code-folding works not correct (SF Bug #1050483).
10) HTML export uses wrong CSS syntax (SF Bug #1074120).
11) Normal Search does not work with UTF-8 (Unicode) chars > 127 (SF Bug #1200456).
12) Relative paths don't work from command-line with single-instance PN (SF Bug #1161783).
13) Window Dimensions After Un-Maximizing (SF Bug #1167299).
14) File -> New Broken (SF Bug #1221755).
15) Don't exit if save is cancelled for a previously unsaved item.
16) Selecting the XML lexer after another does not correctly style.
17) No code-folding for XML (SF Bug #1212335).
18) Keyword customisation causes hang (SF Bug #1209962).
19) Delete Line same as Cut Line (SF Bug #1234653).
20) "Search Up" box not visible for replace.
21) Bad coloring in Text Clips combo box with non-white window colors (SF Bug #1065666).
22) Tried to open a file twice when that file was not found.
23) VHDL Syntax file inclusion (SF Bug #1165830).
24) Crash when adding a project tool (SF Bug #1195786).
25) Show Lines Numbers" setting does not affect open files (SF Bug #1212355).
26) Toggling syntax highlighting looses word wrap (SF Bug #1151704).
27) Undo/Redo in folded area does not unfold (SF Bug #1286210).
28) PN2 is confused by relative path names (SF Bug #1232939).
29) Docking windows resize to tiny (SF Bug #1018105).
30) Sub-windows initialization issue (SF Bug #1065665).
31) Fixed a bug with default styles and the Plain Text scheme.
