fprintf and other ways to kill RAM
7 posts / 0 new
Is it just me, or when i write say:
fprintf(lcd,"PING!!!NY!!!");
when compiled gcc stores the string into the ram, although the the constant is used only once, the string remains in the ram , for the rest of eternity(or until shutdown/reset)? is there any way to use ram normally?
This has nothing to do with fprintf().
Jörg Wunsch
so constants in general?
The avr-libc documentation would explain the use of fprintf_P and the PSTR() macro.
The result could be an fprintf_P(lcd, PSTR("Your string"));
String literals in general.
This is the only way on a Harvard machine to store a string
literal in a way that makes it compliant to the standard so they
can be passed to standard functions (like those from ).
Jörg Wunsch
isnt there a way at least to optimize it? I have to read string out of the eeprom now, cause i needed all the ram i could get on M162.
String literals can be stored in SRAM (default), or in EEPROM or Flash using variable attributes.
In addition to the standard string utilities in , there are program-space optimized string utilities in .
These utilities will allow you to do all the same things as the standard string utilities, except that the literals (format strings, etc...) can be taken directly out of Flash instead of using RAM as a go-between.
