Using a PC's soundcard as a cheap, low-bandwidth oscilloscope is a well-known trick - quite frequently mentioned here.
(just google "PC Soundcard Oscilloscope")
Just seen this - the same trick on Android (using the mic input):
http://www.electronics-eetimes.c...
There's also an Open-Source USB add-on board for wider input range, BW, etc:
