#define in an #include Header Not Appearing In Scope
24 posts / 0 new
Hello Forum,
I think this maybe an Eclipse issue as I am pretty sure that if #include a header file I should have access to the header files #define values. However, I am positing as I am not 100% sure. An example.
uart.h
#ifndef UART_H
#define UART_H
#include <stdio.h>
#define DATA_BITS
void uart_init_9600( );
char uart_receive_byte( void );
void uart_receive_bytes( char buffer[], uint8_t maximum_buffer_size );
void uart_transmit_byte( uint8_t byte );
void uart_transmit_bytes( const char bytes[] );
#endif /* UART_H */
serial.h
#include <util/delay.h>
#include "uart.h"
int main( void ) {
	uart_init_9600( );		/* works. */
    int dbs = DATA_BITS;    /* UNDECLARED. */
    for( ;; ) {
        uart_transmit_bytes( "Hello World!" ); /* works. */
        _delay_ms( 1000 );
    return 0;
Both the uart_init_9600() and uart_transmit_bytes(char[]) works (as does any new function I create). I just can't get the DATA_BITS to be in scope.
Any idea will be gratefully received...
Kind Regards,
Harold Clements
Yes, you should.
uart.h
#ifndef UART_H  <---- Are you sure that nothing else has defined this??
#define UART_H
#include <stdio.h>
#define DATA_BITS  <---- You are defining the name - but you haven't given it any value!!
serial.h
#include <avr/io.h> 		<---- High risk that UART_H might be defined by something in here?
#include "uart.h"
There is no such thing as "scope" with preprocessor symbols!
For preprocessor issues like this, the thing to do  is to look at the preprocessor output.
With GCC, use -save-temps
https://gcc.gnu.org/onlinedocs/g...
The preprocessor is mostly a simplistic textual replacer.
So
#define DATA_BITS (nothing)
gets preprocessed into
int dbs = (nothing);
No wonder the compiler complains.
JW
You mean it is being reported as "undeclared" in your source browsing editor? Or that the compiler is saying that when this code is built?
If it's simply the editor, you are right, it's an Eclipse issue.
But wait a minute. What are you actually doing with "dbs" anyway? Your code is:
int main( void ) {
    for( ;; ) {
        _delay_ms( 1000 );
    return 0;
Any self respecting compiler is going to look at "dbs" there and say "that is completely pointless" and refuse to have anything to do with the variable. That's certainly true of GCC. It wont create anything called "dbs" here that can be watched or otherwise inspected unless you (a) make it volatile or (b) make it global (or (c) turn the optimiser off).
See my article in Tutorial about the importance of volatile in GCC to understand what's going on here.
EDIT: added hot-link to tutorial
The convention is to put declarations in H files and code in C files.
Your #define simply removes DATA_BITS
So after the pre-processor has run, you get:
    int dbs = ;    /* UNDECLARED. */
    for( ;; ) {
which any decent compiler would barf at.
If you did happen to replace DATA_BITS with some real number like 16
    int dbs = 16;    /* UNDECLARED. */
    for( ;; ) {
You still would not see anything in the debugger.    Since dbs is never referenced,   the Optimiser has probably removed it.
Even if it was used,   it might have gone into a Register.    Studio is not very good at displaying variables that are in Registers.     (but it is a lot better than AS4)
But I wouldn't have thought that it would complain about it being undeclared - as the OP suggests?
As you showed, it expands to literally nothing - so the compiler can't complain that nothing is undeclared!
surprise
If the compiler is complaining that DATA_BITS is undeclared, that means it must be seeing "DATA_BITS" in its input stream - which couldn't happen if the preprocessor had replaced it with nothing!
Hence my suspicion that the #define is not actually happening...
    for( ;; ) {
But see above - the barf would not be about anything being "undeclared".
Or maybe that comment is misleading ...
indecision
Thank you all for your quick responses.
The lack of value in the #define was a typo in this forum post. In the actual code it reads:
#define DATA_BITS   8
As for the pointless declaration:
This was just an example, to show that the #define was undeclared; I did not want to post 50+ lines of pointless code.
Kind Regards,
Harold Clements
That is why you should never, ever manually type the code into a forum post - always copy and past!!
Well, create a minimal example exhibiting the problem, then.
... including the error messages.
JW
Sorry blush
To answer a question in the thread, the problem is not just Eclipse's code parsing, its also with the compiler output.
../serial_json.c: In function 'main':
../serial_json.c:44:12: error: 'DATA_BITS' undeclared (first use in this function)
../serial_json.c:44:12: note: each undeclared identifier is reported only once for each function it appears in
../serial_json.c:44:6: warning: unused variable 'dbs' [-Wunused-variable]
make: *** [serial_json.o] Error 1
There was a suggestion that using the name uart.h might be causing the issue, I will try changing it.
Put
#error "barf here"
just below
#define DATA_BITS
JW
My usual technique in this case is to add:
uart.h
#error "this file definitely being seen/used"
#ifndef UART_H
#define UART_H
#include <stdio.h>
 etc.
Now build - do you hit the #error? If not something is preventing this particular uart.h from being seen during the build.
If you do see the error then move it to the other side of the ifndef UART_H guard. How about now?
Ultimately put it on the line above/below the line where you think DATA_BITS is defined - how about now?
Jan and I clearly singing from the same song sheet! :-)
No, that wasn't what I suggested!
What I suggested was that the name of your include guard - UART_H - might be causing the issue.
And I suggested that you look at the preprocessor output to check.
But adding some judicious #errors, as others have suggested, would also do it...
PS
Does GCC support #warning or #message or similar...?
I get #error is thrown before and after #ifndef UART_H and #define UART_H and also...
In file included from ../uart.c:25:0:
../uart.h:23:2: error: #error "error before DATA_BITS define"
../uart.h:25:2: error: #error "error after DATA_BITS define"
make: *** [uart.o] Error 1
Thanks again for your time...
Time to look at  the preprocessor output, then...
My next guess is an "unprintable" in the text of:
so it's not matching "DATA_BITS" that we now know is defined in uart.h.
Either that or the int dbs= line is just an innocent victim of some error on a preceding line within the 50 lines we didn't get to see above it?
A further technique in debugging headers is that GCC has a switch to tell the preprocessor to announce all the .h files it is processing and the order in which that occurs. That could be "interesting" but be ready for a lot of very verbose output!
EDIT just reminded myself it is -H. Wouldn't you know it would be virtually the last option on this page in the manual..
to pass -H to the pre-pro (not compiler or linker) invoke avr-gcc but use -Wp,-H which passes the option on to the pre-pro.
EDIT2: an example on a file that has an empty main() and just includes <avr/io.h>...
~$ avr-gcc -mmcu=atmega16 -Wp,-H avr.c -o avr.elf
. /usr/lib/gcc/avr/4.5.3/../../../avr/include/avr/io.h
.. /usr/lib/gcc/avr/4.5.3/../../../avr/include/avr/sfr_defs.h
... /usr/lib/gcc/avr/4.5.3/../../../avr/include/inttypes.h
.... /usr/lib/gcc/avr/4.5.3/include/stdint.h
..... /usr/lib/gcc/avr/4.5.3/../../../avr/include/stdint.h
.. /usr/lib/gcc/avr/4.5.3/../../../avr/include/avr/iom16.h
.. /usr/lib/gcc/avr/4.5.3/../../../avr/include/avr/portpins.h
.. /usr/lib/gcc/avr/4.5.3/../../../avr/include/avr/common.h
.. /usr/lib/gcc/avr/4.5.3/../../../avr/include/avr/version.h
.. /usr/lib/gcc/avr/4.5.3/../../../avr/include/avr/fuse.h
.. /usr/lib/gcc/avr/4.5.3/../../../avr/include/avr/lock.h
(who knew there were two stdint.h's ?!?)
Or, perhaps, an unprintable in the definition in uart.h - so that it is actually defining something other than "DATA_BITS"
Thank you again, I will open the uart.h file in a hex editor and check for a "unprintable" character, then try the header debugging...(watch this space)...
Thanks again for all your time a effort guys, it's very much appreciated...
Kind Regards,
Harold Clements
> unprintable
... in which case the recommendation changes from "copy and paste" to "zip and post"...
JW
(PS. Andy, copy and past, nice typo ;-) )
You also need to do the same check on the .c file that's trying to use "DATA_BITS"...
OK guys, I know the problem is with Eclipse. I have created my own "make" file and all builds...
I don't have a clue what my miss-configuration is in Eclipse, but I am going  to have fun finding out (or not!).
Cheers Guys...
Harold Clements
