Can not open .h files to edit [6.2.1153]
4 posts / 0 new
I recently did an uninstall and reinstall on 6.2.  Now I am having issues opening .h files.
If I right click from the solution explorer I get.
Object reference not set to and instance of an object
If I "include in project" it opens normally
When I try File | Open | File | main.h I get,
The operation could not be completed. Unspecified error
The operation could not be completed. Unspecified error.
If I try to open a file that is NOT in the project folder. It opens normally.
If I recall correctly, I should not be adding .h files to the compile list and I am 95% sure that this is a new problem for me.
(on Win 7 SP1 64 bit)
For now I am "include in project" everything
Kirk
PS I did another uninstall/reinstall with no change.
PPS. If I right click in the .c file and select "Go to implementation" the .h file opens fine
Can you please create new project in Atmel Studio and copy the project files in the new project and try.
Great idea Micky2.  I made a new project. Copied some .c & .h files to the project folder and I have the same results. :(
In fact .c files have the same behavior as .h files
I guess you are using Atmel Studio 6.2.1153. Atmel Studio6.2.1563 latest version is available for download. http://www.atmel.com/tools/ATMEL...
Can you download this and try to reproduce with this latest version.
