RTOS and atmega128 ?
10 posts / 0 new
Guys,
I tried to port RTOS to atmega128 and I got this ;
Error    3    undefined reference to `vPortYield'  on file tasks.c
Any clues on fixing it ?
thanks
What RTOS?
Just read the message carefully:
It's telling you that you have tried to reference (ie, use) something called 'vPortYield' somewhere in the file tasks.c - but that 'vPortYield' is undefined.
Was that not clear?
Obviously, the fix for something being undefined is to define it!
What RTOS?
[RTOS Support] an optimization in vPortYield() - FreeRTOS
from the first Google hit.
There must be many many worked examples on the Net for FreeRTOS and Mega128.  Right?
Thanks for the info I got 10 errors, did I download the wrong task.c ?
Error    4    undefined reference to `pvPortMalloc'    tasks.c    1    1    freertosm128
Error    6    undefined reference to `vPortFree'         tasks.c    1    1    freertosm128
Error    7    undefined reference to `pxPortInitialiseStack'   tasks.c    1    1    freertosm128
Error    9    undefined reference to `xPortStartScheduler'    tasks.c    1    1    freertosm128
I can't see anything related with those one column 1 and line 1 ??
To make a clear explaination, I attached the complete project  I've been fiddling, thanks for the time seeing it...
So those definition is not available on tasks.c, where can I find it ? thanks
Have you read the manual?
I tried to read manual, but don't know which part of manual related with it ? memory management ?
Or I can't use ATMEGA128 with RTOS, since it has 4Kbyte of RAM only, I'm not interested using external RAM...there's no external RAM chip on my PCB...
thanks
I reckon this one will help....
http://www.freertos.org/a00098.html I'll give it a go later today....
WARNING: threat to life force ahead.
Ross, that's my job! He's sucked enough of mine- life force that is. HeHeHe.
Bianchi,
To fix this kind of problem you are either going to need to:
a) lean C and how to generically fix problems
b) learn to read manuals and in particular the FreeRTOS one to fix this specific issue
c) at least learn to use grep and find things in source trees
d) just wait for someone to give you the working code here and go away without actually having really learnt anything.
If you look at the unpacked FreeRTOS files you will see that the "generic" files are in FreeRTOS/Source. But it's not enough to just take tasks.c or timers.c or queue.c from that directory and add them to your project and think you suddenly have a complete FreeRTOS project. You don't.
Now if you look at your unresolved errors the first is pvPortMalloc. If you grep the source tree for that you will find a number of implementations. Five of them are under Source/portable/MemMang/heap*.c. Now I didn't know why there'd be five so I googled "pvPortMalloc site:freertos.org" and the top hit was this page:
http://www.freertos.org/a00111.html
So it seems clear to me that you have to pick ONE of those heap_N.c files and add it to your project. If feeling adventurous you could provide your own implementation of pvPortMalloc and vPortFree() that simply map the calls to the AVR-LibC implementations of malloc() and free() - in fact this could actually be the easiest solution.
Resolving this actually clears the first two errors in your list of four, The next one is pxPortInitialiseStack. That one is easy to find and highlights the fact that while you took portmacro.h from Source/portable/GCC/ATMega325 for some strange reason you forgot to take the port.c that is there and add it to the files in your Zip. When you do that it will resolve the call to pxPortInitialiseStack.
As it happens xPortStartScheduler() is in that port.c too so when you add that you will have cleared all four errors.
I have shown you how I diagnosed and fixed the errors here. If you want to have any hope of ever becoming a serious programmer you are going to have to learn to employ the same diagnostic technique. It starts with knowing that the error "undefined reference to ..." basically means "I looked through all the .c files in this project but I cannot find the one that is providing ...". That tells you that you probably forgot to pick up and add some .c file to your project.
We now know that you forgot to add two .c files. The second one was easy: grep found that. The first one was maybe not so obvious and required both a bit of grepping and a bit of then reading the FreeRTOS manual to understand why there were a number of heap_N.c files that might be used to satisfy the call to the mallo/free functions.
