RTC and the 32K ULP osc
4 posts / 0 new
How do you set the RTC to run from the 32K ULP osc? I want to use this to wake the CPU up after delays of 150mS to several seconds, I think.
Without adult supervision.
On RTC there is application note "AVR1314: Using the XMEGA Real Time Counter" (with example code)
For using the RTC for wake up you should look at "AVR1010: Minimizing the power consumption of Atmel AVR XMEGA devices". In the example code it has a "xmega_rtc32_sleep_example.c"
But the stinking app notes don't give you register names.
Here it is, RTCCTRL under "System Clocks." I was looking under "Oscillators" and "Real Time Counter."
Actually, it's CLK.RTCCTRL.
