Possible bug with 4.8.2 / 4.8.1
4 posts / 0 new
Maybe it's bad C on my part, maybe it's a bug.
The following happens with 4.8.1 from ATMEL. 4.8.2 from MHV.  It does not happen with 4.3.x and does not happen with 4.9.2 from MobileChess.
The C code is
uint8_t newObject(uint8_t obType, uint8_t lane, uint8_t z){
uint8_t NewObjNum;
ObjectDescStruct *Current;
drawFunctionPointer_t firstActionFunction;
NewObjNum = getFreeObject();             // Get the next free object from the store.  returns MAX+1 if no objects left
if(NewObjNum != (MAX_OBJS+1)) {
     ObjectStore[NewObjNum].obType     = obType;                 // Copy values into object structure.
     ObjectStore[NewObjNum].laneHi     = lane;
     ObjectStore[NewObjNum].z          = z;
     ObjectStore[NewObjNum].r          = pgm_read_byte(&laneAngles[web].lane[lane]);
     ObjectStore[NewObjNum].animation  = 0;
     Current = (ObjectDescStruct*)&ObjectStore[NewObjNum];      // create a pointer to the object structure
     firstActionFunction = (drawFunctionPointer_t)pgm_read_word(&firstActionFunctionPointers[obType]);
     if(firstActionFunction != NULL) {
          firstActionFunction(Current);
     moveXYCommon(Current);                                    // call moveXYCommon to make sure object is on screen
}                                                              // before first call to renderer
return(NewObjNum);
The non working ASM that 4.8.x makes does this
    adiw     r26, 0x07	; 7
    st	     X, r1
    movw	r24, r26
    call	0x9944	; 0x9944 <moveXYCommon>
The compiler has previously gotten the address of ObjectStore[NewObjNum] into R26
It then does some ADIW to it for loading the structure.
It then takes this trashed version of R26 and passes it to moveXYCommon().
In 4.9.2 it makes a copy of the address into R16 before trashing it then does
    adiw	r26, 0x07	; 7
    st  	X, r1
    movw	r24, r16
    call	0x9984	; 0x9984 <moveXYCommon>
I can also force 4.8.x to work by moving the pointer assigment above all the assigments loading the structure with data.
thankfully looks like it is fixed in 4.9.x but just a heads that might save someone else a few days hunting phantom bugs.
...trashed version of R26...
Hmmm--that has a very  familiar ring...
https://www.avrfreaks.net/forum/a...
Not the same bug though I guess.  I am not using memx at all and this bug is fixed already in 4.9.2
BTW - I have changed the code to be more orthodox looking
uint8_t NewObjNum;
	Current->obType  	= obType;
	Current->laneHi		= lane;
	Current->z			= z;
	Current->r 			= pgm_read_byte(&laneAngles[web].lane[lane]);
	Current->animation 	= 0;
return(NewObjNum);
and now no versions of the compiler screw up
Reading through the bug list I think it might have been related to this one
https://gcc.gnu.org/bugzilla/sho...
