Does USART in ATxmega128A1U-AU are multiplexed?
6 posts / 0 new
We have below technical queries regarding ATxmega128A3U-AUR and ATxmega128A1U-AU microcontrollers.
  1. In the data sheet it is mentioned that there are 7 and 8 UARTs respectively however, in the data sheet while looking at the Pin out description, it can be seen that there are only 2 UARTS (UART0 and UART1) with multiplexed pins on different ports. Can you please let us know if we can use more than 2 UARTS (in our case we wish to use 3) in the design which should work indepnedently simulataneously?
  2. Regarding evaluation board STK600 for ATxmega128A1U-AU, it does not contain the USB functionality in it. Can you please let us know the evaluation board which contain USB functionality as well.
Hi !
Each port has its own UART(s). When the datasheet says for example PORTC:USART0-USART1 it means that there are 2 independant UARTs on the PORTC. Depending on the device, it can be 0, 1 or 2 UARTs on PORTx. You'll have to look at the datasheet.
Since it is really a module each time, i.e. USARTC0, USARTC1, USARTD0, ... I would say that they are independant. But I recommend to test first !!
Regarding a dev board, the A3BU xplained comes to my mind.
Have a nice day,
Kraal
1. You can do this by using interrupts. Each of the the up to 7 UART/USART has its own I/O pins. See application note AVR1307 for sample code.
2. eg "XMEGA A1U Xplained Pro Evaluation Kit" has USB support. (http://www.atmel.com/tools/atxmegaa1u-xpro.aspx)
The  two USARTs on a port are independent.
Welcome to the Forum.
Just to be clear, all of the USARTs are independent.
Whereas an old AVR would have UART0, UART1, USART2, ... UART7, the xmegas add the port designator as well.  Quoting the A1 datasheet:
PORTC, PORTD, PORTE, and PORTF each has two USARTs.
Notation of these peripherals are USARTC0, USARTC1, USARTD0, USARTD1, USARTE0, USARTE1, USARTF0, USARTF1, respectively.
