Computer Languages
24 posts / 0 new
A series on Radio 4 about programming languages...
http://www.bbc.co.uk/programmes/...
Ah-ha.   I think that I will skip the Cobol episode.
I once did a training course on COBOL. They thought I was "disruptive" and the company chose not to continue my employment at the end of it. (I may have questioned what appeared to be "dinosaur" practices!). Luckily that same week I found and got the job I then spent the next 25 years doing :-)
Never used COBOL outside required classes.
Once, exiting a data structures class taught in Pascal, a student said, "Sure wish we could get back to COBOL where you can get something done."
Of course, HE probably has a job now...
Although not in so many words, I'm sure I've heard 'C' programmers express such opinions...
Yeah but the most boring job in the world! Who wants to write stock control or sales or insurance software? COBOL is probably the computing equivalent of the monkeys+typewriters=shakespeare thing!
My sister used to work in COBOL.
Yes,    some years ago,   there was quite a demand for COBOL experience to maintain obsolete systems.
Somehow,   a new job in COBOL in the 21st century would mean supporting 40 year old software.
Seems like someone would sell a cobol2c converter. There are basic2c and fortran2c converters.
Bob, somehow i'd be thinking a Cobol to Java or to php might be the go at the present time. Having been immersed in php and javascript doing web stuff for the last year, i think C is like the new age assembler - only used by the high priests of coding.
Not only have i been swapping from php to javascript and back on a regular basis, but throw in some lua, objective C and sql. My poor brain has trouble keeping up. Now there's talk of adapting some C++ code using QT that has some funky templating that gcc doesnt like but MS C++ does, my challenges are neverending.
One thing that has been shown is the basic structure of the code is near identical regardless of the actual language its implemented in.
Yes, for procedural languages.
There are non-procedural languages like
Prolog
SQL
perhaps LISP
hehe
Imagine those old patched altered and modified COBOL programs maintained for the last 40 years that nobody really knows what they do any more... translated to LISP
translated to APL!
C is basically Assembly, sans carry flag but with structure. It's the only thing keeping me sane on the day job. I *can* and do write PIC assembly if I have to, but I'd far rather let the compiler do it for me.
Neil
p.s. I currently have a C program occupying most of an 8k chip, a file management system. It is possible/probable that I may have to squeeze that into a 4k chip - so that'll be machine code. Meh.
Neil
Recode to shrink by 50% in going from C to ASM - unlikely. And very expensive in labor. that much NRE make sense if you're building $M units.
I have a tidbit of empirical evidence that you can use to goad the boss into believing that cmos atmel chips can take a lickin and keep on tickin. The L3 crash hardened recorder that is used in most flight and data recorders was probably in the plane that dug a hole in the mountain. They make those in Clearwater Florida. I've been on the tour of the facility. They are designed to survive a full speed crash into a mountain, and a 12 hour diesel fuel fire, and unfortunately, I think they demonstrated that they meet that spec. They use atmel dataflash chips. inside a steel bowling ball with the only thing peeking out is a ribbon cable. The flight recorder writes harvard biphase to the crash memory. We made the flight recorder boards... similar to pc104 form factor but the recorder is a stack of avr boards with dual port rams that communicate over a backplane bus. I wrote the harvard biphase part on a mega128. I betcha those boogers would work down in the hole.
DesiSmileys.com
Ross McKenzie, Melbourne Australia
A former co-worker squeezed a 256 byte bootloader via assembly language onto an 8-bit MPU.
An AVR equivalent is the PJRC HalfKay USB bootloader.
Worthwhile and rewarding efforts.
May you have victory!
Conversely, when each unit has a price of millions USD (most anything attached to a rocket motor) and a similar cost (pre-launch, launch, operations, risk abatement).
These do appear to be moving away from 8-bit MCUs to 16-bit MCUs or a few 32-bit MPUs.
An example is Intersil moved the CDP1802 8-bit MPU to a secondary position with the 80C86 as primary.
Another example is the CubeSat MCUs are now 16-bit (IIRC two or three architectures); CubeSat plus launch is about 200kUSD.
With the larger address space comes matching storage (external RAM, non-volatile) so very likely a HLL for the computer language.
If you have a working system i C, and you wrote it your self (not just copied ), my guess is that it will take less time to write it in ASM, than it took to make the first version.
My advice is to make a very good plan, of register use, very important is the use of XYZ, how to place shared variables (those that has to be volatile), 16 bit atomic can work without disabling ISR etc etc
And if size really matter, it's important to find where speed matter and get that fast, so the rest can run like and simple interpretor of some kind. (an interpretor can be written in something  like 10 instructions).
I keep getting emails saying it does cheeky
Yeah, I once wrote a bootloader that used one byte. Well, I say one byte, a couple of bits were empty. Nice to have room for future expansion.
A whole byte? Luxury!
(with apologies to Monty Python's Four Yorkshiremen)
Who wants sense when "because It can be done" is cool.
KolibriOS
http://kolibrios.org/en/
... a few megabyte disk space and 8MB of RAM to run.
Have you ever dreamed of a system that boots in less than 10 seconds from power-on to working GUI, on $100 PC?
This speed is achieved since the core parts of KolibriOS (kernel and drivers) are written entirely in FASM assembly language!
On-Disk.com
KolibriOS, The Fastest Desktop Operating System on Earth!
http://on-disk.com/product_info.php/cPath/488/products_id/1625
AdaCore
Home / Company / Press / SPARK Going to the Moon
Liverpool (UK) – UK Space Conference, New York, and Paris, July 14, 2015
http://www.adacore.com/press/spark-going-to-the-moon
Vermont Technical College writing flight software for Lunar IceCube, will use GNAT Pro and SPARK
Lunar IceCube is a 6-Unit CubeSat mission to prospect for water and other lunar volatiles in all forms (solid, liquid, and vapor) ...
