Does someone is using flip with XMega devices?
I attempted to use flip on ATXMega64A3U, but Windows 7 keeps complaining that the driver cannot be found.
Installing the drivers found in the flip directory fails. Googling around I found other persons who can't run flip on W7, you can also download some "special" drivers that should solve the problem. But no luck with them, either :-(
So, if someone was able to run flip, please give me some hints.
Thanks!
